Radiators & HELP!
Old Sep 24, 2001 | 10:33 AM
jcs1966's Avatar
jcs1966
Radiators & HELP!
Everyone talks about adding AUTO trans to 1966 trucks and I would like too but dont I need a different radiator for the AUTO trans?
Also Need answers to prior posts!!
Old Sep 24, 2001 | 10:45 AM
mattb's Avatar
mattb
Radiators & HELP!
no you dont need a different radiator to convert. all you need is as transmission cooler. it looks kind of like a small radiator, but it only has trans fluid running through it. they cost about $50 for a good one. get the largest one you can afford. your trans will thank you.
matt
mattbalfanz(No Email Addresses In Posts!)
1965 f100 long bed
352
c6 conversion
2400 stall
TCI manual/automatic valve body
ratchet shifter
locker
4.10's
moser axles
disc brakes
power steering
viper yeller with perdy flames
Old Sep 24, 2001 | 11:23 AM
Franklin2's Avatar
Franklin2
Radiators & HELP!
If the aftermarket cooler is your only option, then go for it, but a cooler in the radiator is actually better in the winter, as it actually warms the fluid for better operation. Find a good radiator shop in your area, and I bet they can take your tank off your existing radiator and install a cooler from another they have laying around.
Old Sep 24, 2001 | 10:29 PM
jbhf250's Avatar
jbhf250
Radiators & HELP!
ihcc104
WTB - Parts & other
Aug 5, 2014 09:02 PM
TexasTornado66
May 7, 2010 01:40 AM
2004Lightning
13
Mar 25, 2009 04:50 PM
RTRF350
Feb 27, 2007 07:52 PM
jcs1966
Nov 2, 2001 05:02 PM
