outside keypad install
Old Sep 9, 2006 | 04:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
can an outside keypad be used to work aftermarket electric door locks??
i had aftermarket power locks and windows on my 88, and have gotten used to having the keypad on the crown vic. it is allot easier to leave a key in the ashtray and open the door by the keypad then it is to carry a keyring full of keys for 6 vehicles, house, shop, gates, etc,etc.
Old Sep 9, 2006 | 08:09 PM
Franklin2's Avatar
Franklin2
You already have the keypad system, and you have installed aftermarket locks? I would think you could get it to work.
You do not have a keypad and want to add it? Anything is possible, but I would not know where to begin with that. You would need a module of some sort that goes with the keypad. I know in some years it's included in the GEM module.
One possible simple way would be to hardwire the keypad so you have to push two buttons at the same time. Not as secure, but not many people push two buttons at once to unlock a Ford vehicle so it might work fairly well.
Old Sep 9, 2006 | 08:34 PM
Rockledge's Avatar
Rockledge
Have you contacted the manufacturer of your aftermarket lock system and asked them about it? Maybe they offer something.
Old Sep 10, 2006 | 04:20 AM
tjc transport
i ain't rite
OK Dave, i guess i should have been more specific.
i put the locks and windows in back in 89. i do not have a keypad. i was just toying with the idea, cause the key in the ashtray and door keypad works so well with the crown vic. and since i am doing power windows and locks in the falcon when i put it back together, i was thinking about doing it to that also.
and i have no idea where i got the kits from to ask them if they have something that will work. i lost all my files when the computer crashed, and like an idiot, i had nothing backed up.
Old Sep 11, 2006 | 12:25 PM
Franklin2's Avatar
Franklin2
Well, if you had a keypad, and it looked like you could use it just as a regular switch, you could run a small 12 volt wire up to one of the pads, then run over to another pad, and then back down to a foglamp relay. Pushing the two keypad buttons together would complete the circuit and activate the relay.
Or possibly your system already has a relay? I doubt the keypad switches would handle the full current of the door lock solenoids. The relay would activate the locks.
Or, you could go aftermarket with an alarm system and a key fob. I hate alarm systems(I know depending on where you live they are required) but it would activate your locks with a remote.
Old Sep 11, 2006 | 01:49 PM
tjc transport
i ain't rite
i agree Dave, i feel alarms suck puppy muffins also.
i never thought about sending the keypad to a relay.
good idea. i will have to investigate the pad triggering a relay further
Old Sep 12, 2006 | 11:06 AM
charlez's Avatar
charlez
Maybe one of these will work for you.
Just tap your code on the glass for entry.
http://www.taplock.com/
Just a basic Remote Keyless setup. There is a 3rd remote that sticks to the door and uses a code. (Just like the one on a garage door)
http://www.keyless.com/KE-1600%20Main.htm
A hardwired one on ebay.
Touch-Key
Redneck1465
Nov 8, 2011 04:00 PM
tankkillr
Jun 12, 2011 12:03 PM
tkiner
2009 - 2014 F150
Jan 11, 2010 01:27 PM
Johnny Mo
Feb 6, 2002 11:29 AM
galta
Oct 12, 2001 05:10 PM
