Sponsored by: Real Truck
speedometer problem
Old Sep 9, 2006 | 09:25 AM
someday's Avatar
someday
speedometer problem
my 05 speedomter reads anywhere from over 100mph at a stop or 0 at any speed...ive already replaced the speed sensor in the diff...its a kr so it has the electonic dash...on older models i was able to test the gauges by holding the reset button and turning the key on but on the new models that doesnt work...does anyone know how to check the gauges on newer model trucks? everything still functions normally (cruise, abs, etc)...anything else anyone can recommend i should check
Old Sep 9, 2006 | 01:18 PM
ReAX's Avatar
ReAX
Being it's an 05, there still should be some kind of warranty available. I would suspect the cluster is damaged, it's a common problem on chevy digital dashes. The only problem I every remember on a ford is our 84 Tbird cluster light went out and we couldn't read the speedo.
Old Sep 9, 2006 | 01:39 PM
oldkountryboy's Avatar
oldkountryboy
not sure on the newer trucks but i know on the older ones most everything on the dash ran thru an general electronics module, my started acting up and would not let my dash or brake lights work,
i would think that it would be the gem or the cluster
Old Sep 12, 2006 | 10:25 AM
someday's Avatar
someday
apparently it was a problem on some of the 05s...has anyone had their clusters replaced?...it is still under warranty but im out of town now and dont know or trust any dealers...im scared my dash is going to get all scratched up to get to the cluster
Old Sep 12, 2006 | 12:37 PM
kw5413's Avatar
kw5413
Don't know if this will help but, worth a try:
Various Electronic and Driveability Symptoms and Codes:
2005 F-Super Duty trucks built before 5-11-05 may exhibit various electronic-related symptoms due to loose/miss-installed fuses in the engine compartment fuse box. These symptoms may be intermittent. The fuses should be inspected to verify they are installed into the terminals in the fuse box and not along side the terminals.
Fuses--Symptoms
#9, 20 amp: Trailer turn signals inoperative
#10, 10 amp: Check Engine Light; Codes P1633, P0446
#11, 10 amp: Speedo bounce, ABS light, Cruise control inop; Codes U1900, U2023, P0500-P0503
#12, 2 amp: Cruise control inop, TBC Fault displayed, chime; Code C2803
#13, 15 amp: Day time running lamps inop
#15, 15 amp: Crank/no start, bucking, stall; Codes P2614, P2617, P1378
#17, 10 amp: A/C inop or not cooling
#18, 10 amp: Crank/no start, bucking, stall; P2614, P2617, P1378, P0611
#20, 10 amp: Trailer back up lamp inop
TSB 05-11-14
Old Sep 12, 2006 | 02:02 PM
someday's Avatar
someday
ill give it a try but a ford tech told me that with my symptoms the cluster would more than likely have to be changed...i ate $60 for the vehicle speed sensor but im more reluctant to bite the bullet on the cluster ~$350 and i never got my fuel retainer clip recall done
Old Sep 12, 2006 | 02:53 PM
kw5413's Avatar
kw5413
While you are checking, try this as well:
2005 F-Series Speedometer Needle Bounce, Cruise Control Drop Out, DTC P0500, and/or Uncommanded Wiper Activation:
If any of the above conditions are present, inspect the wiring harness running behind the coolant bottle to the wiper motor for chafing on a brake line clip and shorting to ground. If harness damage is found, repair and insulate the damage, and secure the harness away from the clip. Broadcast Message 3695.
Old Sep 12, 2006 | 03:18 PM
jorand's Avatar
jorand
Speedo issue
Similar problem on my 06 F250 PSD CC FX4 Lariat. Had the issue about a month ago where the speedo was reading 100+ while driving through residential streets, took to dealer and they couldn't find a problem. Had the issue again, this time dealer saw it as well. You could turn the truck off and see the speedo sitting at 70+.....................very strange.
So, after they diagnosed a unrelated alternator problem and installed a new one, they have decided to replace the dash cluster. No trouble codes were found though, but they have had another truck with the same issue and feel that changing the cluster will eliminate the issue.
Old Sep 14, 2006 | 09:41 AM
someday's Avatar
someday
exactly the same problem as mine...so far no problems with the new cluster and did they damage any of the dash to get it off (scratches, alignment issues, etc)?
Old Sep 14, 2006 | 10:32 AM
jorand's Avatar
jorand
Speedo issue
Nope - No damage, no scratches (I have the wood grain dash), everything works. Of course, I will be keeping my eye on everything to see if it acts up again. I guess the cluster means everything you see on the dash. They replaced everything. I also had a new alternator installed because it was occasionally lighting the battery light.
Old Sep 14, 2006 | 11:27 AM
Customz's Avatar
Customz
I've had my speedo inop on 2 occaisions. Just read 0 at various speeds, then started working outta the blue. It only stopped working for a few minutes, I have not checked the wires or performed any tsb recommendations.
Goatjacket
Aug 12, 2012 07:24 PM
Sheryle
Apr 30, 2008 07:38 PM
JD717
1983 - 2012 Ranger & B-Series
Feb 15, 2006 02:00 PM
nikbass
Aftermarket Products
Jun 29, 2004 08:57 PM
garyc
1997 - 2003 F150
Nov 7, 2001 10:03 PM
