1978 - 1996 Big Bronco
black marks when turning
Old Sep 8, 2006 | 08:46 PM
78fordranger's Avatar
78fordranger
Hey my 78 bronco leaves black marks when I turn sharp and it is starting to wear on my tires pretty good. Do any of you have the same problem? Is it just the short wheel base causeing this?
Old Sep 8, 2006 | 09:00 PM
greystreak92's Avatar
greystreak92
Are your hubs locked? Does your 78 have the rather rare full-time 4WD option? Either can cause bind in the front axle when executing tight turns.
Old Sep 9, 2006 | 12:26 PM
dwoodler's Avatar
dwoodler
Your alignment might be out a bit too, and then you are draggin' one tire around the bend.
Old Sep 9, 2006 | 09:23 PM
78fordranger
I have locking hubs and I can spin the front drive line when there not locked so I dont think they are sticking locked. It does it both ways I turn. I use to drive a 85 K5 blazer for work and it did the same thing when I turned sharp. So i thought it was common on these broncos but maybe it is aligment. I will have it checked when I put new tires on next month. Thanks for the info
Old Sep 9, 2006 | 11:31 PM
chrono4's Avatar
chrono4
could just be a soft compound of the tire. The all-terrains on the 78 do it too, theres marks all over the driveway.
Old Sep 22, 2006 | 08:56 PM
muddinboy's Avatar
muddinboy
my bronco does the same thing but its cause the tires tow in around corners, ifs is the problem for me tho.
Old Sep 23, 2006 | 07:04 PM
78fordranger
my does too they like to lean way over when i turn
ClintonA
Dec 18, 2016 10:05 PM
djmichael24951
40
Jul 9, 2016 07:33 AM
78fordguy
20
May 5, 2015 02:11 PM
mark4000
1983 - 2012 Ranger & B-Series
Feb 7, 2012 12:46 PM
J. E. Ray
2004 - 2008 F150
25
Mar 9, 2004 10:53 PM
