c6 shift arm/lever removal?????
Old Sep 8, 2006 | 06:47 PM
70_f100's Avatar
70_f100
I am puting a later model c6 in my 70 f100, I want to use the shifting arm off my old tranny. I am sure this comes off easy, but I cant see how it comes off with all the grease on it.
Old Sep 8, 2006 | 07:05 PM
kennethl6's Avatar
kennethl6
Remover the small nut that holds the kickdown lever and remove. Then pull the pan and valve body to get to the large nut that holds the internal link to the outside manual linkage.
Old Sep 8, 2006 | 10:00 PM
ivanribic's Avatar
ivanribic
Ken said it all but just to reiterate you cannot remove that shift lever just from the outside of the tranny. You have to pull the valve body to get to the retaining nut inside.
Old Sep 8, 2006 | 10:35 PM
70_f100's Avatar
70_f100
Thanks for the help, however shortly after posting, I discovered the transmission they brought me at the salvage yard is for the early ford diesels. Good thing I kept my recipt.
Nick Greer
Feb 20, 2022 05:15 AM
Nick-1973-ford
Sep 12, 2016 09:19 PM
drptop70ss
Aug 10, 2015 12:20 PM
69issofine
May 15, 2015 08:35 PM
CaptCameltoe
Apr 22, 2013 10:26 PM
