flush
Old Sep 8, 2006 | 01:33 PM
dboys3021's Avatar
dboys3021
flush
How do i flush my radiator on my 2001 expi can u please help?
Old Sep 8, 2006 | 05:46 PM
FTE Herman's Avatar
FTE Herman
There's a post you can read about it right here: https://www.ford-trucks.com/forums/5...iscolored.html
Hope this helps!
Old Sep 8, 2006 | 07:07 PM
Mr.Novice's Avatar
Mr.Novice
That post recommends running the engine while filling with a garden hose? Really? I've always used Distilled Water in my radiator. To do this, I drain the radiator, fill it up with distilled water, Run the engine for a minute, and repeat until the water is clear. Then drain and add the proper mixture of AntiFreeze.
hkiefus, would you agree that that is better than using water from your garden hose?
At the very least, I would drain the hose water and refill with distilled after I was done with the method mentioned in the mentioned link...
Is this just "old school thought", or is distilled water better?
Looking forward to hear what you have to say.
Old Sep 8, 2006 | 08:38 PM
ronk1969's Avatar
ronk1969
regular old tap water works fine. I Have never heard of using distilled water . Have you always done that ? just kinda curious.
Old Sep 8, 2006 | 08:40 PM
BowTieHatr's Avatar
BowTieHatr
distilled water has less minerals like iron deposits and other thing that cause havoc in a cooling system, but for flushing tap water is fine. but when filling use distilled.
Old Sep 9, 2006 | 10:11 AM
Mr.Novice's Avatar
Mr.Novice
Yeah, I've always used distilled. I think that even in my Chilton manual it says to use distilled water.
comsupany
Mar 24, 2016 05:06 AM
DaveTV
Escape & Escape Hybrid
Sep 30, 2015 07:48 AM
rawdeal
Mar 30, 2014 05:44 PM
onuredneck707
Aug 31, 2011 10:24 PM
69ford99
2004 - 2008 F150
Sep 5, 2009 09:47 PM
