stumbling 400
Old Sep 7, 2006 | 05:45 PM
THEBOOGIEMAN's Avatar
THEBOOGIEMAN
stumbling 400
my 400 stumbles a bit when i first mash the gas, but it passes and then runs just fine till i change gears or hit the gas agin.
Old Sep 7, 2006 | 06:55 PM
montana105's Avatar
montana105
Sounds like fuel delivery.Changed your filter recently? If so check your float level and power valve along with timing. Might be time for a carb rebuild,new gaskets and check valves do wonders for these old trucks and pretty cheaply I might add. John
Old Sep 8, 2006 | 03:57 PM
LxMan1's Avatar
LxMan1
Vacuum advance working properly? Accelerator pump working?
Old Sep 10, 2006 | 05:18 PM
THEBOOGIEMAN
I do not know.
I am not to good with a carb, or fuel system.
Old Dec 4, 2006 | 09:51 PM
bareaneye's Avatar
bareaneye
Are you using a Holley carb? If so, check the power valve. Mine was too small and would stumble from idle, but when I go it going it was OK. Changed the power valve after getting the right one and it was like I had a new truck!!
blake8105
Feb 19, 2015 10:59 PM
Jklnhyd
Jul 13, 2014 10:16 PM
ck27
New Member Introductions
Nov 9, 2007 10:10 PM
carp1
Nov 20, 2003 06:54 PM
blue_mule
Dec 3, 2002 04:31 PM
