Carter Carb with off idle stumble
Old Nov 17, 2003 | 06:31 PM
carp1's Avatar
carp1
Hello
I have a 400 and I just put a carter carb on it and now I have a bad stumble from 1000 to 1400. I think it is about were it transfers from idle to the primary circuit. Any guesses on how to fix this? It idles good and runs down the road good just taking off slowly it stumbles bad. In drive and brake on at 1000 to 1400 it runs rough and surges.
Thanks
Chad
Old Nov 17, 2003 | 07:34 PM
danlee's Avatar
danlee
What size carb is it?
Old Nov 17, 2003 | 07:44 PM
carp1's Avatar
carp1
The carb is a 625 cfm. I had the carb on the truck when I had it rebuilt about 50,000 mile ago. I had a shutter in the engine then so I put a holley on it then found out that I had an internal vaccum leak "manifold would not seal" Got that fix so I decided to put the Carter back on. Then is started to stutter. I just put it back on this morning.
Thanks
Chad
Old Nov 17, 2003 | 08:01 PM
danlee's Avatar
danlee
It sounds like a 'lean' mixture. Are you sure that vacuum leak is fixed?
You could try to change the metering rods to give a richer mixture in 'cruise'.
How about your accelerator pump and float level? If your float level is too low, then there is no fuel in the accelerator pump at light throttle.
Old Nov 17, 2003 | 08:18 PM
carp1's Avatar
carp1
Everything is set to the specs. I think you can rule out the accel pump because it you torque up the engine with the brake on it surges and stumbles I dont think the accel pump has an affect on it holding at one constant speed. Right now the carb is still jetted stock. It seems like it is having trouble going from the idle circuit to the primary circuit. Once you pass that point it runs great. Free reving at that rpm does do it a little but not like under a load.
Thanks
Chad
Old Nov 17, 2003 | 08:28 PM
danlee's Avatar
danlee
It still sounds 'lean'. Try one step richer in the metering rods. If that doesn't work call Edelbrock and tell them it's a 1406.
Old Nov 17, 2003 | 08:31 PM
carp1's Avatar
carp1
Thanks for the help. I will play with it tomorrow. I have the tuning kit so that will be easy. Thanks again.
Chad
Old Nov 20, 2003 | 06:54 PM
carp1's Avatar
carp1
Hello
Danlee, Just letting you know that I bumped up the metering rods and that took the stumble out. Thanks again for your help. Its nice to have other opinions on things.
Thanks
Chad
Old Brown F250
15
Feb 12, 2014 04:59 AM
baverwolf
20
May 7, 2010 09:59 AM
jbielenda
Sep 18, 2009 11:44 AM
79F150400M
Jul 17, 2004 03:18 AM
