Bronco II Ford Bronco II
88 Bii
Old Sep 21, 2006 | 08:51 PM
eisle89's Avatar
eisle89
You have a Schrader valve on the fuel rail, with the key on, the fuel pump should buzz for about 10 seconds and if you depress the needle in the valve gas should shoot up ( I use a rag ) When you installed the TFI did you disconnect the battery ?? This will reset your computer and is a good idea for all such work on the electrics. I use the cheapo thermal paste ( you can get at Radio Shack ) that is used on computer chips instead of the Dielectric grease. The theory is that heat will be tranferred to the distributors' body and away from the TFI module. Here in the desert it's really important and this method seems to work very well.
Old Sep 21, 2006 | 10:42 PM
Dealford's Avatar
Dealford
Another Link....
About TFI modules.
http://www.geocities.com/MotorCity/Flats/3349/test.htm
AL.
NicktheBrit
Apr 11, 2014 01:44 PM
GunnyBeaty
1983 - 2012 Ranger & B-Series
Jan 30, 2012 08:37 AM
Sirpecka
Nov 22, 2011 08:44 AM
chipper
May 29, 2007 07:00 PM
Kallie
1978 - 1996 Big Bronco
Jul 1, 2003 03:07 AM
