7.3 glow plug issue
Old Nov 21, 2011 | 10:04 PM
Sirpecka's Avatar
Sirpecka
7.3 glow plug issue
Well i bought a truck this summer and it runs just dandy. But now that its getting cold its not starting so well. The glow plugs done come on at all when you turn the key. I replaced the glow plug cylanoidand still nothing at all. I want to know what else can I check before tearing the valve covers off and changing the plugs which I really done want to do.
Old Nov 21, 2011 | 11:15 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Nov 21, 2011 | 11:53 PM
snakedoc's Avatar
snakedoc
if the GP relay is working and the wires to the GP or good then the GP most be bad.
you can ohm the GP throught the wires with out taking the CV off they should be in around 0.8-1.5
Old Nov 22, 2011 | 01:26 AM
carltonwebb's Avatar
carltonwebb
Might get someone to check your starter draw too. Been a few of those pulling too many amps lately and making for a hard cold start.
Make sure your new GPR is working by checking voltage on both big lugs of it with the key on. Sometimes a new part will fail.
Old Nov 22, 2011 | 06:59 AM
Ponyboychris's Avatar
Ponyboychris
Here's some good threads to read through: https://www.ford-trucks.com/forums/1...ky-thread.html
Old Nov 22, 2011 | 08:44 AM
Brother Les's Avatar
Brother Les
pulled from another thread
Get a plug in Voltage meter now, you will be glad you did
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="670"><!-- / icon and title --><!-- message -->Wednesday morning, jumped in the truck, 35 degrees and she did not want to start at all... The usual was going through my head. Low Batts... thick oil.... GPR problem..... (The wife glaring at me because we might be late for work). I said..' Let me check the Batts and the GPR'. I reached into the center console and pulled out the Voltmeter that plugs in the accessary plug and plugged it in. 12.49 volts..... Good... Hit the switch to the 'wait to start'....12.39 volts.... This was not good as I knew that the voltage should drop at least to 11.5 and it did not even get close. I told the wife the the GPR is bad and I will pick on up that night..... Then the truck started. My wife was impressed (thanks guys)
Last night I went to NAPA and asked for a GPR 109 (order by part number instead of year/model if you can) and it came to 25.00. I asked for a AAA discount and got that too. After paying I asked about the 'Warrenty'. (I knew that I had bought one there a couple of years before) He said .... 3 Years or 36,000 miles. ( I thought that it would be one year warrenty) I thought that I have bought one there in 2009 and was that under 'warrenty'? Yep... January 2009. He said to bring in the old one and He would refund my money. I 'almost' got three years out of it.... and now I will get this one free.
The GPR on my truck had in the Last few weeks stoppe, as I use the 'volt accessary' every couple of weeks and the GPR was working fine at that time. As I was taking the nut off of the hot wire side, the post snapped out of the unit. Yep... it was melted and brittle. Replace it all at home and no cost of GPR unit or a call to a mechanic.
Thanks to the people here at FTE, I knew what was going on with the 'no start' and knew where to look for the bad part AND how to fix it myself.
My recomandation is to get a plug in volt meter and check your electrical system out before the snow starts flying and your stuck BECAUSE you did not know that your GPR was not working.
Easy to check each and every time you get in:
1)Checks Batt voltage... (12.4 v)
2)Checks voltage drop when GPR engages (or if it does not engage) (1v drop to 11.5) (truck Must have 10.5 v to start)
3)Tells you when the GPR shuts off (voltage will start to rise from 11.5)
4)Checks output of your Alternator output (14.4v)
<!-- / message --><!-- sig -->__________________
DrCharles
Dec 10, 2017 06:20 PM
Vinford
Oct 31, 2017 04:00 AM
Bvill01
Mar 3, 2016 10:27 AM
Phillyrube
Apr 2, 2008 09:23 AM
mhalter
Jan 14, 2003 01:24 AM
