tranys
Old Sep 6, 2006 | 09:24 PM
94inline6's Avatar
94inline6
tranys
i dont know if this is the right place to put this but here it goes would a 351 out of a70 mach 1 bolt up to a 5 speed trany in a 93 F-150
Old Sep 6, 2006 | 09:56 PM
havi's Avatar
havi
I'll have the Roast Duck
yes and no. if the 93 had a 351w originally, then it should bolt in, but you'll need the newer flywheel, and maybe a couple other things. More importantly, running a carbed 351W will need a lot of work with efi fuel pressures and such. Lots of crossover stuff. Bolting on the newer efi intake won't work due to different chambers and such from 1970. Try the windsor series forum, and maybe the engine swap forum.
PS: just by chance I looked in a 79 supercab at the local JY, and found a 1970 351W, too.
Old Sep 6, 2006 | 10:05 PM
bob s jr's Avatar
bob s jr
what engine is in the 93
Old Sep 7, 2006 | 05:06 PM
94inline6's Avatar
94inline6
thanks "what engine is in the 93" 300 6
Old Sep 7, 2006 | 06:17 PM
havi's Avatar
havi
lot's more work, then, with mounts and stuff.
Old Sep 7, 2006 | 08:02 PM
bob s jr's Avatar
bob s jr
300 six has the same bell housing as 351 local parts store will have the mounts for you a donner truck of the same year out your local yunk yard will get your pully brackets and lower frame engine mounts and flywheel also able to find the manifold harness and injection and computer for it reasanably once you get the parts its afairly easy swap all bolt on
Old Sep 7, 2006 | 10:06 PM
94inline6's Avatar
94inline6
thanks guys
Old Sep 7, 2006 | 10:07 PM
bob s jr's Avatar
bob s jr
your welcome
