96 Explorer intermittent starting problems
Old Sep 20, 2006 | 01:40 PM
mommysangelsus's Avatar
mommysangelsus
my truck is a 99 and i am having problems sometimes starting not here latly now mines seems to try to not shift well HELP!
Old Sep 20, 2006 | 02:25 PM
ctacree's Avatar
ctacree
Good luck, I'll keep you posted
Old Sep 22, 2006 | 11:44 AM
jl2695's Avatar
jl2695
well it's been two days and so far so good. Even on the short trips where I used to have problems the car has started right up every time. I think the relays did the trick. One thing I noticed when changing the relays is that they were extremely hot. The metal spades burned my fingers. This doesn't seem right to me. Any ideas?
Old Sep 24, 2006 | 09:52 AM
ctacree's Avatar
ctacree
Smile
Great, I have not had any additional problems as well. The relays will be hot, since when the engine is running the relays will be entergized and will have current going through the winding, which creates heat. So I don't believe the heat is a concern, except that it may shorten the life of the relay.
Good luck
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
TN_Explorer
Aug 20, 2016 07:45 PM
Joel D
110
Aug 22, 2015 09:52 PM
chintonmd
35
Sep 20, 2012 11:26 PM
mattklionsky
1997 - 2003 F150
Aug 2, 2001 11:00 PM
