engine runs rough
Old Nov 13, 2001 | 07:37 PM
robber1's Avatar
robber1
Post engine runs rough
Just got '64 F100 223 c.i. three on the tree. Had mechanic tune and put on rebuilt carb. After it warms up engine runs real rough,backfires and stalls at stop signs.. Mechanic thought it was the oil bath air cleaner, but removing it does not help. Any ideas?
Old Nov 13, 2001 | 09:22 PM
whomrig's Avatar
whomrig
engine runs rough
Sounds like a vacuum leak or maybe two crossed plug wires.
Wayne Homrig
1960 F-350
http://www.pacbell.net/whomrig
Old Nov 13, 2001 | 09:49 PM
robber1's Avatar
robber1
engine runs rough
When I first start driving, it runs smooth. It is only after it warms up the it runs rough. Another thing I noticed, when it starts to run rough, the clutch shudders, chatters in first gear. I don't get it
Old Nov 14, 2001 | 07:58 AM
44dwarf's Avatar
44dwarf
engine runs rough
Grab a hold of your coil if it is hot, take a look at your points! You may find that the arm is dicolored and the gap has closed up. The truck will run fine when cold but not when warm cause it needs more ign power when hot. If you find the pionts fried take a volt meter and measure the coil voltage (from coil + term to ground with truck running) you should see no more then 10 volts. If you see more make sure your mechanical voltage regulator is working. Mine was not and I had the same problem as you AutoZone has a soild state one for 11.99 Then change pionts and condencer.
Best of luck.
44Dwarf
PS: may truck ran good after the volt reg change but runs Great now withthe MSD 6a ignition.
Old Nov 14, 2001 | 07:20 PM
66ranger's Avatar
66ranger
engine runs rough
cscott952
Sep 10, 2016 06:34 AM
m50
52
Aug 18, 2016 10:46 AM
LFPENN1974
Jun 21, 2016 10:20 AM
KyleeCook
1978 - 1996 Big Bronco
Mar 24, 2016 11:45 AM
txcowboy67
Sep 19, 2005 03:27 PM
