Engine Missing
Old Jul 13, 2016 | 08:16 PM
m50's Avatar
m50
Engine Missing
My 96 7.3 was setting in the garage and not been driven for several weeks, it was running fine when I parked it I had just put a new mechanical fuel pump on it. I started it to drive it and it is running but really rough with no power. Like it has 1 or 2 dead cyl.
It did have a battery that was a dead short , I replaced that and changed the fuel filter, but it still runs rough. Anyone have any ideas?
Thanks in advance.
Thanks RB
Old Jul 13, 2016 | 08:46 PM
Red97350's Avatar
Red97350
I would start by checking the UVCH. Possibly have a burned plug or two?
Red
Old Jul 13, 2016 | 09:15 PM
m50's Avatar
m50
Red
what is the UVCH?
Thanks Red
Old Jul 13, 2016 | 09:23 PM
Red97350's Avatar
Red97350
Under Valve Cover Harness. The wiring under the valve covers. The connectors have a tendency to melt.
Red
Old Jul 21, 2016 | 01:01 PM
m50's Avatar
m50
Red
Is this something that could happen when the truck is just setting?
How can I tell if the wiring harness is bad?
thanks again RB
Old Jul 21, 2016 | 01:13 PM
cowmilker08's Avatar
cowmilker08
How much have you driven the truck since you changed fuel pumps? Could just be some air in the system.
There are two 5-wire plugs on valve cover gasket on each head. Unplug them and look for melted plastic and burnt pins or signs of arcing.
Old Jul 21, 2016 | 01:24 PM
m50's Avatar
m50
I drove the truck about 200 miles after the fuel pump replacement.
Those wires have been replaced about 10k miles ago.
It just seems wierd that it was running great when I parked it.
Thanks RB
Old Jul 21, 2016 | 01:35 PM
knottyrope's Avatar
knottyrope
what is fuel pressure at Schrader valve?
Connectors can fall off
can be IPR nut is loose
low oil can cause lack of power
more than 1/4 tank of fuel?
Old Jul 21, 2016 | 06:09 PM
m50's Avatar
m50
thanks for some more ideas, I will check these out and report back.
RB
Old Jul 22, 2016 | 07:51 AM
cowmilker08
What brand parts? Please don't say Dorman.
Old Jul 28, 2016 | 08:23 PM
m50's Avatar
m50
Ok I have finally had time to work on my truck for a little while.
I had to wait on a turbo intake boot that I got from Riff Raff, great guys!
I had 57 psi at schrader valve.
All the connectors looked good , nice and shiny. There was a little dampness in 1 looked oily.
Full of oil.
both tanks full of fuel.
Not sure where the IPR nut is?
Any more ideas?
Thanks RB
Old Jul 29, 2016 | 08:00 AM
m50's Avatar
m50
How much pressure should be on the schrader valve at idle?
RB
Old Jul 29, 2016 | 08:42 AM
knottyrope's Avatar
knottyrope
you need min 40 PSI at idle and at WOT under load
IPR is behind HPOP down low near valley, there is a tin nut on it and it can get loose
Old Jul 29, 2016 | 07:52 PM
fordguy390's Avatar
fordguy390
I had an issue a while back but it turned out to be a loose injector connection on UVCH. UVCH is always the first thing I check on my 7.3. Mine lost power and sounded really. If you put it in drive and stall on the converter at 900 rpm and the truck shakes I would unplug each pig tail at a time (running and in park) on the valve cover and you should notice a huge difference if you unplug one and if notice a little difference in sound that pinpoints out 2 injectors. I would check connections before buying a new wiring harness.
Old Jul 30, 2016 | 04:28 AM
m50's Avatar
m50
Ok I will look at them again, (mine look good, shiny and clean but a little oily) and try the unplug idea also.
Is the connections on the topside of the valve covers usually the problem or a connection actually under the valve cover?
Thanks RB
