Error Codes on Dash Display
Old Sep 5, 2006 | 10:31 PM
hmolivas's Avatar
hmolivas
Question Error Codes on Dash Display
Hi Everyone !!!
Im the new guy and had some questions.
I have an 04 F-150 super crew lariat. (this would make it my 3rd FORD )
I recently have seen 2 errors on my dash display. They are as follows :
1.Autolamp delay data error
2.Auto lock data error
Can anyone help me with this ? I just bought the truck (used) therefore its out of warranty.
Also the radio stays on when I shut off the truck and pull the key out. its stays on for a while (5 mins or so) and then shuts off. Is this normal ? can it be disabled?
ANY HELP WOULD BE GREATLY APPECIATED .
Old Sep 5, 2006 | 11:21 PM
1979FordF-250's Avatar
1979FordF-250
Exclamation
I can tell you that there is something wrong with your radio. It should shut off at the off position where you can remove the keys. It should never play for 5min after you take the keys out.
Old Sep 5, 2006 | 11:27 PM
cool guy's Avatar
cool guy
there's nothing wrong with your radio, open up the door and it will turn off......it's normal, i got the same setup .... it has the delay timer...
Old Sep 5, 2006 | 11:30 PM
cool guy's Avatar
cool guy
for your error codes check your manual how to reset it or just disable it through your mini message center....and see if you can turn it on again....
Old Sep 6, 2006 | 05:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Olivas, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 6, 2006 | 06:21 PM
hmolivas's Avatar
hmolivas
Thanks for the info guys !!
Coolguy- I do open the door. I open it get out of the truck lock the truck and the radio is still playing (wierd huh??)
as fas as the codes go. The message center will not let me reset them.
would this utimately turn out to be a dealer issue?
Old Sep 7, 2006 | 06:29 AM
cool guy's Avatar
cool guy
that is wierd! well i guest your right about the dealership fix....see if someone else could help you through this issue in here....
Old Sep 7, 2006 | 06:45 AM
96f150's Avatar
96f150
Just for kicks, do your power windows still work with the key in off position? If so, your RAP (retained accessory power) module may be bad. Just a thought
Old Sep 7, 2006 | 06:10 PM
hmolivas's Avatar
hmolivas
yes they do
That make sense and sounds like a source to look at. do you know where FORD put this module?
I looked at Mitchell and it was kind of vague on where this module is
Old Oct 22, 2013 | 04:23 PM
pearlofagirl100's Avatar
pearlofagirl100
I have the exact same problem. hmolivas, did you ever get it fixed? What did you have to do exactly?
trmann
Aug 7, 2012 11:40 AM
StephanieStroh
Sep 20, 2011 09:48 PM
tylem28
6.4L Power Stroke Diesel
Nov 22, 2010 09:43 PM
raptor2005
Feb 15, 2010 03:03 PM
planet89
2004 - 2008 F150
Feb 27, 2009 03:03 PM
