just about to get her back on the road
its been 6 months since shes ran and been pulled apart so guys please bear with me
got a few questions for ya
workin on my 90 bronco
302 five speed eddie bauer
got a rebuilt older 302 carbureted dura spark 2 engine complete
what all do i need to hook up the dura spark system in my bronco?(doin away with the computer and fuel injection)
hold on hold on I know here comes all the questions you know (why go back to carb? fuel mileage angles while wheeling ) well want to make it simple and fun
what harmonic balancer do i use the one off the engine that had the clutch or the one that came with the moter? was automatic
got a fuel pressure regulater is there any tricks on trickin the fuel pump to work with a carb engine
thanks in advance
john
thanks in advance
john
On the fuel pump, sure, find the relay under the hood and wire it to a power feed on the "ON" side of the ignition. Done. Whatever you do, DON'T bypass the interia switch. Leave it in there! The electronic pump will not shut down in a collision if the engine stops or a fuel line ruptures otherwise. Be careful too, the pressure in the line from the EFI pump hovers around 35-40 psi. Thats a LOT more than the typical carb setup will EVER need. Your connections to the FPR that you have need to be extremely secure.
I can't answer the balancer question for certain but I would think you need one for the older engine on the older engine.
Duraspark? oi vei... um, I honestly don't know. The Duraspark system does not compensate for timing changes as the engine wears in (i.e. chain stretch, spring lag, etc.) So as the engine gets older the ability to get it to run well on the Duraspark system gets more complicated to achieve. In that regard, if you want simpler, go to an aftermarket high energy ignition. Just an opinion.
You are gonna get a lot of contradictions about the term "simple" because the EFI is actually more reliable AND simpler to troubleshoot. But thats all I'm gonna say.
wanting to get er done
hey thanks grey its been awhile just trying to use what is already there i knew that the ignition off the newer style that i already have wouldnt work my problem is the heads if they would work with my fuely intake i would switch it all over but not shure the heads have the egr ports in the back like my fuely heads just wondering whats the difference?what is a good after market ignition to get that is oh what is the word CHEAP? THANKS
As long as the heads were manufactured after 1976, they should have the Thermactor air injection ports/manifolds cast into them.
Folks around here often extoll the virtues of MSD ignition systems. Not too familiar with the aftermarket systems as I have gotten very accustomed to the OEM setup on mine. Might try a search... I know the topic has been covered before.
ScallyWaggler
05-16-2015 02:17 AM
I'mforgiven
01-01-2015 12:59 PM
KrautBurner
05-01-2014 09:42 AM
Sooper Camper
09-17-2013 01:49 AM
earthworms
03-19-2001 04:40 PM
