I went to drain and refill my differential today with fresh gear oil and could not for the life of me find a drain plug on the bottom of the "pumpkin". Do some differentials not have drain plugs?
There is or may be a fill plug on the rear of the housing. Using a suction pump (looks like a grease gun) and pull the old grease out and refill with new.
As mentioned before, you can use an oil suction hose (about 1/4 inch dia.) through the fill plug hole, you can pop off the front of the differential after dropping the driveshaft (more labor intensive including gasket and crush seals), or pull one axle and elevate the other side (not recommended because you couldn't get enough oil out and the elevation would be dangerous). The best way to completely remove the 90W oil is to pull the pumpkin. Then you have the ability to inspect axles and bearings, center section & gears, and you will be able to wipe any build-up from the bottom of the axle housing.
Enzo, I was surprised to find out as you did that there is no drain plug for the diff. Well guess what? There is one there now. I drilled and tapped for a 1/4" pipe plug ( can't remember the drill size right off ) . I've been changing the diff lube every two years since then and it works great. I use a little teflon tape when reinstalling the plug and all is well. After I tapped the drain hole, I flushed out the housing with safety solvent twice to get out any small metal pieces that may have gotten up into the housing. Drill slowly and use copious amounts of WD40 to wash away the fillings before you get all the way through the housing. I had success minimizing the amount of filings as very few washed out with the solvent. I then changed the gear lube after about 100 miles but I found nothing in the lube. Steve
Steve.....I like your solution. I think I'll try the suction pump first and see if I get enough of the old oil out first. Having a workable drain plug is a great idea.
i will second that. iv not messed with mine too much, but thats certainly worthy of drilling and tapping if I ever seen it. where about on the sucker did you place the plug?
can you post a piccy of it?
The '66 just went off to college with my son so pictures will have to wait until he comes home during the holidays. I will call him and see if he will measure the location. The hole has to favor the rear a bit to avoid the internal webbing of the casting. It does not let 100% of the lube out but much more that siphoning and way easier. Steve
