Replacement brake lines 48-52
Old Sep 18, 2006 | 04:19 PM
AXracer's Avatar
AXracer
it's not a pressure issue, but more vibration concern and to add flexibility during installation. It's kinda hard to insert a straight line into a fitting at each end especially if it passes through something so you can't bow it in the center, adding a U bend gives a spot where the line can temporarily shorten when you go to pop it into the second fitting. The U bend or Z bend also breaks a long section into two shorter sections, each less likely to vibrate. I also recommend using plastic or plastic lined clamps to hang the lines with.
Old Sep 20, 2006 | 11:30 PM
oscarxyz's Avatar
oscarxyz
Great....
Now I don't know if I should give it a try or run away screaming.
I did enjoy the feedback on your experiences though.
Oscar
51truck
Nov 18, 2013 07:12 PM
fatrhino
Aug 26, 2008 03:26 PM
terrypen
Sep 20, 2006 12:17 PM
StL_F150
Sep 29, 2004 08:42 AM
WoodN1_76
24
Jun 23, 2003 09:18 PM
