Sponsored by: Real Truck
Oil Pan Patch
Old Sep 3, 2006 | 09:16 AM
DickyBoy's Avatar
DickyBoy
Oil Pan Patch
The oil pan on an E-250 Id like to buy has a rot hole the size of a half dollar....They say you have to lift the engine just to replace the pan so....Im lokking for a sure fire way to patch It.....Thanks
Old Sep 3, 2006 | 09:22 AM
FortyFords's Avatar
FortyFords
replace the pan ! you don't want the rust flakes floating around inside the engine!
Its not that hard to change the pan.
Rich
Old Sep 3, 2006 | 09:39 AM
DickyBoy's Avatar
DickyBoy
I agree....but where the van Is stuck It will be hard enough to patch never mind replace....When I get It out and up I,ll be able to replace It...
Old Sep 3, 2006 | 09:56 AM
FORDDIEHARD's Avatar
FORDDIEHARD
Patch for the Pan
What I have done in the past was to make sure the pan has all the oil residue removed by useing carb cleaner or something comprable then mix up some JB Weld only enough to fix area and apply to the pan. Usually I will use the non quick set formula which sets up in about 20 minutes. Did this to a 97 E-250 and it has held to this day! Hope this helps, it's a great quick fix.
Tim
Old Sep 3, 2006 | 11:27 AM
vettdvr's Avatar
vettdvr
I would reco. at least have it brazed if not replaced. But just another opinion worth about $.01. Jim
johnsteffy
23
Sep 22, 2010 07:23 PM
unregistered guest
Sep 6, 2010 11:40 AM
bridgeman
Oct 8, 2007 10:28 AM
marragtop
Feb 27, 2007 04:05 PM
jjp
Nov 13, 2005 05:45 PM
