Exhaust help
Old Sep 3, 2006 | 12:25 AM
smits03's Avatar
smits03
Exhaust help
I've got a 99 5.4 and true duals and i have noticed a torque loss and was wanting to regain some of that torque. i want a nice deep tone that has a little rumble to it. Any advice i'm thinking Flowmaster Super 40 DI/DO, but i'm not sure i could go with a Magnaflow. If i do teh flowmaster is DI/DO going to regain torque or do i need to go SI/DO??
Old Sep 3, 2006 | 02:51 PM
RangerPilot's Avatar
RangerPilot
What size pipe did you use on your true duals?
Old Sep 4, 2006 | 10:29 AM
smits03's Avatar
smits03
Pipe size is 2.5 in and out
Old Sep 4, 2006 | 01:10 PM
RangerPilot
With true duals, 2.5" is too big, you need smaller than that to keep your torque, plus a an H-pipe to even things out.
If you want to go muffler, I'd suggest headers to a Y-pipe, SI/DO muffler, dump it or run it to the back as you see fit.
Old Sep 4, 2006 | 02:54 PM
kens64's Avatar
kens64
Did you reset the PCM? Where are your o2 sensors and are you running MIL eliminators? What did you do with your cats?
With the bigger pipe, midrange torque will be boosted, enough sometimes for someone to think low end is gone since it will pull harder at higher RPMs.
Old Sep 4, 2006 | 07:21 PM
smits03's Avatar
smits03
the 02s and the cats are all still factory it's true duals back from the cats. if i decide to go with a muffle what do you guys suggest?
Old Sep 4, 2006 | 09:17 PM
RangerPilot
The Flowmaster 40 series, as widespread as it is, is a good muffler. If you want a good loud rumble, that's the way to go. For just a rumble, run the pipes after the muffler out the back of the truck. For a loud rumble, dump it right after the muffler.
I'd suggest a single-in dual out.
Old Sep 6, 2006 | 11:16 PM
351M's Avatar
351M
Dual in dual out Magnaflow should do the trick, you could get 2.25" tails put on after the mufflers. Go with an 18" body length.
Old Sep 7, 2006 | 12:50 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
Dual out on a Flowmaster 40 close after the muffler will definitely give the deep rumble:
Some other options are listed here:
http://motorhaven.autoanything.com/exhausts-mufflers/20A50460A1.aspx?kc=MOTORH
Old Sep 7, 2006 | 06:39 PM
RangerPilot
I can agree with ToughBuiltFord, I have a Flowmaster 40 that's dumped immediately post-muffler and it's very very deep and rumbly lol.
Old Sep 11, 2006 | 09:53 PM
Mr. Man's Avatar
Mr. Man
I have heard that simply adding a X-Pipe to a true dual system will really help with low end power and torque, I heard this from a guy on the forum. He has straights with stock cats, true duals, and a x pipe. He said he once had true duals with no linkage inbetween, and when he added the x pipe it was a huge difference, really helped the scavenging of the exhaust. I personally have a 4.6L with high flow cats, 2.5" true dual straights(no linkage whatsoever), angled out the back with 5X22" SS tips, I did notice a big drop in low end, but gained a lot at around 2000 and up. Just a lil info I thought might be somewhat useful.
Old Sep 12, 2006 | 10:23 PM
351M's Avatar
351M
The main reason you noticed the loss was because you went with 2.5" pipes, if you add an X then yes it will help. But you wouldn't have noticed it as much if at all if you had gone with 2.25", tune the exhaust and it makes a big difference as well.
bscoffey
1997 - 2003 F150
Dec 14, 2014 07:49 AM
Soneway
Jan 27, 2014 03:15 PM
428fourby
2004 - 2008 F150
Apr 2, 2009 09:44 AM
timmyjimmy5150
Exhaust Systems
Apr 20, 2006 12:26 AM
Mcyktor98
Exhaust Systems
Oct 4, 2004 05:48 PM
