Modular V10 (6.8l)
Plugs...COP's.......
Old Sep 2, 2006 | 10:05 PM
PHWLEE's Avatar
PHWLEE
I have a 2003 F250 V-10 with about 48K miles on it. I am trying to do as much on my own that is possible to keep the truck running like a top. I feel she is running a little sluggish right now and have so far cleaned the MAF sensor (didn't look dirty) and will also check the fuel filter once hurricane Ernesto leaves. I would like to check the spark plugs, but have never worked on an engine with fuel injection. I like the old style with the plug boots staring right at you. Does anyone here have a picture, or a link of a picture that can show me the EXACT picture with instructions on where and how to remove the plugs?? Coil Over Plugs...... which are the COD's?? If I know that, I can find the plugs....... also, they look like they are attached to some sort of air line..........can anyone give me concise, step by step's to removing the plugs?? Thanks.
Old Sep 2, 2006 | 11:34 PM
heidiandmax's Avatar
heidiandmax
I just changed mine recently.The cod are just below the fuel rail.they are round and have a electrical connector.Push the release for the connector at the bottom and disconnect.Now pull up and out,now you will see the plug in the hole.I will try to find a post that might be helpful......
Old Sep 2, 2006 | 11:38 PM
heidiandmax
Heres the thread;
https://www.ford-trucks.com/forums/4...th-photos.html
Just like to add having air to blow out the area and plug hole is invaluable.FWIW
Old Sep 3, 2006 | 09:19 AM
PHWLEE's Avatar
PHWLEE
heidiandmax, thanks for that link posting. I have a good idea now of what needs to be done. I do have an air compressor with a pinhole blower to clean out the plug area. I'll give the plugs a look today if the weather holds up.
Old Sep 3, 2006 | 01:16 PM
captchas's Avatar
captchas
Guest
before you touch the plugs change the fuel filter .the v10 dosn't like one thats even a little pluged up. and since we now have the alcieblend gas i have changed a lot of filters due to dirt and gum in the tanks.
if you do the plugs make sure you never sieze them and install with a torque wrench , "change the boots as a precaution", so you don't over tighten them and cause a blow out with a plug
Old Sep 3, 2006 | 01:27 PM
PHWLEE's Avatar
PHWLEE
I went under the truck and found the fuel filter. Being a holiday weekend, I am not even going to try to go pick up a new one. Looks like it needs a special tool to remove the lines. As for the spark plugs, they don't look so easy either. Hopefully, I will be able to remove the COP and the plugs without having to touch those injector lines. Never worked on an injected engine, so this is a first for me.
Old Sep 3, 2006 | 01:32 PM
captchas's Avatar
captchas
Guest
krewat has a thread posed on how to and you sure don't touch the injectors to do the job. takes about 3 hours total when you get going and have every thing lined up that you need .
good luck but it just not as hard as it looks .
Old Sep 3, 2006 | 02:20 PM
heidiandmax
This was my first plug change on my v10 myself.The only thing I removed was the hose from the throttle body to the air cleaner and the PCV valve/hose.The hardest plugs to reach are #4 & #5.The other 8 are a peice of cake..
Good luck to ya!
Old Sep 3, 2006 | 09:31 PM
PHWLEE's Avatar
PHWLEE
I removed the first COP and now see how they are setup. I took a look down into the spark plug "chamber" but didn't want to go further because I didn't have the replacement plugs with me. (more like exploratory research today) Now I also see why the need for the air compressor to blow out that chamber of any dirt that may have collected - before removing the spark plug. You know, a shop vac would work too....hemm... or a shop vac AND an air hose.
By looking at the other COP's and how they are sitting with that injector line right above it, I thought that line might have to be moved.... but after thinking about it, once I remove the brass screw securing the COP, it should wiggle out from under that line.
Okay, I see I have my work cut out for me this week............ Maybe tomorrow if the auto stores are open. Thanks for all of the info.
tmehrkam
Modular V10 (6.8l)
71
Mar 19, 2025 10:22 PM
JWA
Apr 16, 2019 08:27 PM
cantedvalveFord
33
Jun 13, 2016 08:46 AM
rvpuller
Modular V8 (4.6L, 5.4L)
May 15, 2016 04:10 PM
Torsen Rick
Aerostar
46
Sep 10, 2010 12:30 PM
