1978 - 1996 Big Bronco
96 Bronco won't start
Old Sep 2, 2006 | 07:58 PM
lthawk's Avatar
lthawk
Hello, this is my first post to this board. I have a 96 Eddie Bauer Bronco, 66,000 miles. My problem is that after parking it this am, I tried to start the thing and got the click click click like a dead battery. The battery however is charged and I also tried a jump box. Seems to be plenty of juice. I am not a mechanic obviously, so any ideas? If so, can I simply change out a part or have it towed to a service station. Thanks for your help.
Old Sep 2, 2006 | 10:01 PM
screwy's Avatar
screwy
Solenoid, Bad ground, starter, corroded battery terminals.
Old Sep 2, 2006 | 10:15 PM
Streetgang's Avatar
Streetgang
Yes as screwy says....check your leads, and also check the terminals. Make very sure the ground connections are clean and tight. If you do nit find the problem there check your starter relay on the right side inner fender wall.
If you have a Hayns manual it gives a outstanding troubleshooting guide for "no start" conditions.
Old Sep 3, 2006 | 11:01 AM
lthawk's Avatar
lthawk
bigdan1979f-250
Jun 5, 2016 09:08 PM
D Thomas
Feb 26, 2016 04:35 PM
corbit96
Sep 16, 2014 06:56 PM
Bodaddio
Apr 26, 2010 12:14 AM
mmhud
Jul 19, 2004 08:48 PM
