HI everbody. I am new to this forum. Did a quick search on ABS lights. Just wanna see if I am having a VSS problem? My 2000 F250SD V10 4X4 has the ABS light on after I start to roll down the road. It does not leave a code. There are some times that the Speedo does not work and then it does. The truck has 130,000 miles on it.
Will replacing the rear sensor on it solve my problem and changing the diff fluid?
I do not see wires going to the front.
Also How hard is it to fix the door ajar light? The truck has the xtra cab suicide doors.
Change the sensor its a cheap piece of mind at that many miles.
Change the fluid if its never been done.
door ajar is usually the switches getting stuck ,a heavey spray of wd-40 in the latch area of the door takes care of most problems.
Rich
