Hypertech 41029 Tuner
Old Sep 1, 2006 | 03:11 PM
briank's Avatar
briank
Is anyone using one of these on their truck? I just bought one from someone but it turns out that it is still programmed to their VIN. Is there anyway to clear/unlock it or do I have to send it to Hypertech?
Thanks,
Brian
99 F250 SD, CC
83 Econoline Van/truck
62/63/65/67 Ford Econoline van and PU
Old Sep 1, 2006 | 03:22 PM
aklim's Avatar
aklim
Thanks,
Brian
99 F250 SD, CC
I would think that they would have to download the program from their truck and set it back to stock before it can do anything with yours.
Old Sep 1, 2006 | 04:44 PM
maevans's Avatar
maevans
I"m using the hypertech programmer, And like aklim said, it's only can be used on one truck at a time. You should connect the seller and retrieve the Hypertech program that is probably still in his truck, and return the stock program. Hope this helps.
Old Sep 1, 2006 | 05:06 PM
aklim's Avatar
aklim
If not, 3 of use could share a programmer. You need the truck it was on or it is a useless piece of junk
Old Sep 1, 2006 | 05:45 PM
briank's Avatar
briank
Thanks for all the info. The guy sold the truck and he thought that he had done that. I will get a hold of Hypertech and see what they say. They should be able to reset it.
Brian
Old Sep 1, 2006 | 06:02 PM
aklim's Avatar
aklim
Brian
The can but probably won't. How do I know that you didn't download a program into your truck and now you are trying to download another program into another truck?
Old Sep 1, 2006 | 06:09 PM
JOE-M's Avatar
JOE-M
They probably will reset it but it will cost nearly as much as a new one. It's worth a call tho. Then try to get your money back from your friend, and let us know what they said about reprogramming it.
Joe
Old Sep 2, 2006 | 11:04 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Think you should get your money back from the seller.
Old Sep 2, 2006 | 11:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Brian
They will do it, but they will charge you the full price of a new one.
You should sell that tuner to the guy that bought the truck and get yourself a fresh one.
Old Sep 3, 2006 | 12:20 AM
aklim's Avatar
aklim
True.
I wouldn't. I now know you have to sell it so I will lowball you. Return it to the seller and be done with it is probably the best thing.
MikeRizz
6.4L Power Stroke Diesel
Jan 11, 2024 10:05 AM
LEDman
Dec 7, 2016 10:28 PM
gstaz
Computer Chips & Tuners
Oct 14, 2016 10:41 AM
steuspeed
Sep 16, 2016 06:12 PM
gixxer1
Aug 6, 2005 07:11 PM
