Somewhere in the drivetrain...
Old Aug 31, 2006 | 10:20 PM
tcbofade's Avatar
tcbofade
I'm stumped. 79 F150 4x4 351M auto. Just developed a shifting problem. Shifts from 1 to 2 normally, but if shifting into 3rd (with my foot on it) the truck bucks like it's fighting itself. Feels exactly like a carrier bearing failing, the whole truck rocks...but I don't have a carrier bearing. U-Joints look good, no play. Transfer case has oil as do both differentials. Where do I look next?
Old Aug 31, 2006 | 10:35 PM
havi's Avatar
havi
I'll have the Roast Duck
tranny fluid? modulator vacuum? does it do it in reverse?
Old Sep 1, 2006 | 07:18 AM
tcbofade's Avatar
tcbofade
Trans fluid looks ok. Modulator was OK at last check, and it still shifts fine under small load. No issue in reverse. If I take the freeway to or from work, I've got a hill to climb while getting on the ramp/getting up to speed. It shifts into 3rd at about 35-40 mph, and bucks like it's losing a piece of something. Took back roads to work yesterday and today, no issue. ????
Old Sep 1, 2006 | 09:53 AM
hunter_firefighter's Avatar
hunter_firefighter
Any possibility of the vacum line to the modulator having a crack or small hole in it I had a ch@#y that did the same thing. Turned out the vacum line was weak and sucking itself shut
Old Sep 1, 2006 | 10:42 AM
tcbofade's Avatar
tcbofade
Possible I suppose. The vacuum line to the modulator didn't look great, but was still providing vacuum at last check. Can't cost more than a couple of bucks to replace...I'll do that this weekend. Thanks.
Old Sep 2, 2006 | 12:15 PM
hunter_firefighter
Let me know if that fixes it.
Old Sep 6, 2006 | 02:17 PM
tcbofade's Avatar
tcbofade
OK, I replaced both sections of rubber vacuum line. To the steel tube on the frame, and from that tube to the modulator itself...survey says...
Nope.
Sorry for the delay. Didn't get to the parts store until yesterday. So this morning I got brave and got on the freeway again. Same thing. Right at 45 or so it shifted into 3rd HARD and the whole truck shook.
Think I'll stick to the backroads for a while.
Any more ideas?
yardape1
Jan 17, 2017 07:42 PM
Lloyd.fry3
Dec 16, 2016 05:54 PM
idealtrucks
Nov 12, 2016 08:59 AM
Platinum08
May 28, 2015 07:52 AM
Pest007
Mar 6, 2015 02:40 PM
