I need to replace the carrier bearing in my truck. 03 250 CCSB 4x4. It looks the parts places list two different id sizes. Does anyone know which one I need??
thanks!
I went to Autozone during lunch today to see what they had, and they have a 35 and 40 mm inner diameter, and 3 different centerline measurements.
Has anyone had to replace theirs and know which one will work?
It's a 5.4 if that matters.
I took my driveshaft to Driveshaft shop and they replaced the carrier and U-Joints with all spicer stuff. Had I had the rear balanced like the front they would've painted it too. Might be worth seeing if there is a local specialty shop like this in your area.
I paid proven Force in Maple Grove to rebuild my driveshaft
Thanks Chris I think that is the way to go, I replaced the Ujoints over the summer and have had a slight vibration ever since. I think I will take it there and they can replace the carrier and rebalance it..
I had a bad carrier bearing and a U joint that was getting a little stiff. Looked at parts prices and even with the balance it was only 100 more to have them do everything. Well worth not horsing around with it myself. That's 3 new u joints carrier bearing, balance and they painted it.
I think it was around 235 or something like that. They had it done same day for me
