Sponsored by: Innova
amp power wire 2001 screw
Old Aug 31, 2006 | 05:05 PM
brettmcox's Avatar
brettmcox
where is a some good places to run a 4g power wire into the cab.
Old Sep 1, 2006 | 08:02 AM
fordboy_52's Avatar
fordboy_52
i go pass side, lower firewall and then drill a hole and insert a grommet. check the posts at the top of the page (back one) and you will find install instructions and tips
GOOD LUCK!
Matt
Old Sep 1, 2006 | 03:24 PM
Frost13's Avatar
Frost13
thats what I did in my 1994 F-150, cept it was an 8 guage.
Old Sep 1, 2006 | 05:14 PM
CBFryman's Avatar
CBFryman
I did drivers side right below the brake vacume booster. Be careful there, however, because you deffanitely dont want to drill into your vacume booster.
CBFryman's Avatar
CBFryman
And mine was for 1/0
Old Sep 1, 2006 | 08:08 PM
cangim's Avatar
cangim
If your truck is an Auto, there should be a semi oval section where there would otherwise have been a clutch assy. You could run it through that, I know on the superduties there is a rubber grommet passenger side under the heater box. If pull the carpet back, then lifted up the black rubber coming down from the heater core along the fire wall, there is a small oval grommet there. I don't know if there is the same thing on the SuperCrew or not.
