75 dash pinout
Aug 31, 2006 | 10:35 AM
75 dash pinout
got a wiring harness for my 75...trying to hook up the dash, installation manual has a 18 pin connection, mine has 14
anyone have a pinout of a 14 pin connector for the dash?
( temp gauge, fuel gauge, oil light, charge light )
Aug 31, 2006 | 11:10 AM
14 Pin is for Idiot lights
18 Pin is for Gauges
They fit with no problem in their respective cluster type.
Aug 31, 2006 | 01:55 PM
Easiest thing to do would be to go get a cluster with gauges from the wreckers and install it.
Try an 80's E series van.
Sep 1, 2006 | 03:06 PM
just trying to figure out which pin(s) in the 14 pin connector go to what wire on the harness...ie...blue/red is what circuit, green red is what, etc???
Sep 1, 2006 | 06:05 PM
I'm confused about this.
So after you have identified which is which .......what happens then ?
Do you plan on altering the wiring circuits ..like trying to place Idiot light wires in a gauge connector ?
Blue/red stripe is for cluster and dash lighting.
Sep 1, 2006 | 06:14 PM
i know what your asking for, what wires go in which number plugs. i dont have that right in front of me, im still toying around with what wires go where.
Sep 1, 2006 | 07:54 PM
I know what he wants too but I would like to know.... Why ?
Sep 6, 2006 | 09:04 AM
Quote:
to install an aftermarket harness
Sep 6, 2006 | 02:25 PM
Ah... see now it makes sense
Who's aftermarket harness are you using ?
I'll see what I can do.
The wire being colour coded helps a lot.
I assume you don't have a Haynes manual.
You should be abe to get the info you need from the autozone site.
Wiring dagram for 76 Truck.
http://www.autozone.com/servlet/UiBr...3d800ce982.jsp
Sep 7, 2006 | 11:57 AM
thanks....will be working tonight
