Aircraft maintenance Issues...
Old Aug 30, 2006 | 12:55 PM
stu37d's Avatar
stu37d
Government Teat-sucker
This may have been posted before, but they are hilarious:
Here are some actual maintenance complaints/problems, generally known as squawks, recently submitted by QANTAS Pilots to maintenance engineers. After attending to the squawks, maintenance crews are required to log the details of the action taken to solve the pilots' squawks.
<HR align=center width="75%">
Problem - Left inside main tire almost needs replacement.
Solution - Almost replaced left inside main tire.
Problem - Test flight OK, except autoland very rough.
Solution - Autoland not installed on this aircraft.
Problem - No. 2 propeller seeping prop fluid.
Solution - No. 2 propeller seepage normal. Nos. 1, 3 and 4 propellers lack normal seepage.
Problem - Something loose in cockpit.
Solution - Something tightened in cockpit.
Problem - Dead bugs on windshield.
Solution - Live bugs on backorder.
Problem - Autopilot in altitude-hold mode produces a 200-fpm descent.
Solution - Cannot reproduce problem on ground.
Problem - Evidence of leak on right main landing gear.
Solution - Evidence removed.
Problem - DME volume unbelievably loud.
Solution - Volume set to more believable level.
Problem - Friction locks cause throttle levers to stick.
Solution - That's what they are there for!
Problem - IFF inoperative.
Solution - IFF always inoperative in OFF mode.
Problem - Suspected crack in windscreen.
Solution - Suspect you're right.
Problem - Number 3 engine missing.
Solution - Engine found on right wing after brief search.
Problem - Aircraft handles funny.
Solution - Aircraft warned to "Straighten up, Fly Right, and Be Serious."
Problem - Target radar hums.
Solution - Reprogrammed target radar with words.
Problem - Mouse in cockpit.
Solution - Cat installed.
Defect: The autopilot doesn't.
Action: IT DOES NOW.
Defect: Seat cushion in 13F smells rotten.
Action: Fresh seat cushion on order.
Defect: Turn & slip indicator ball stuck in center during turns.
Action: Congratulations. You just made your first coordinated turn!
Defect: Whining sound heard on engine shutdown.
Action: Pilot removed from aircraft.
Defect: Pilot's clock inoperative.
Action: Wound clock.
Defect: Autopilot tends to drop a wing when fuel imbalance reaches 500 pounds.
Action: Flight manual limits maximum fuel imbalance to 300 pounds.
Defect: #2 ADF needle runs wild.
Action: Caught and tamed #2 ADF needle.
Defect: Unfamiliar noise coming from #2 engine.
Action: Engine run for four hours. Noise now familiar.
Defect: Noise coming from #2 engine. Sounds like man with little hammer.
Action: Took little hammer away from man in #2 engine.
Defect: Whining noise coming from #2 engine compartment.
Action: Returned little hammer to man in #2 engine.
Defect: Flight attendant cold at altitude.
Action: Ground checks OK.
Defect: 3 roaches in cabin.
Action: 1 roach killed, 1 wounded, 1 got away.
Defect: Weather radar went ape!
Action: Opened radar, let out ape, cleaned up mess!
Old Aug 30, 2006 | 01:50 PM
dono's Avatar
dono
Gone but not forgotten.
I love it!
Old Aug 30, 2006 | 08:15 PM
jake00's Avatar
jake00
those are funny
Old Aug 30, 2006 | 08:46 PM
FTE Herman's Avatar
FTE Herman
My personal favorite.
Old Aug 30, 2006 | 09:25 PM
Greywolf's Avatar
Greywolf
On a headset (this a true NAVY story)
"Left ear does not communicate"
(there was a broken wire)
"FIX SHORT BETWEEN EARS"
"RADALT (radio altimeter, with a limit of 5,000 feet in a helicopter) IS INACURRATE ABOVE 5K"
"SO???"
"EJECTION SEAT DOES NOT FIT CORRECTLY/OP MALFUNCTION POSSIBLE!!!
(this was a string-bean sized LtJg that thought airplanes were made to size)
"SEAT RFI (Ready For Issue) IAW NATOPS- SUGGEST TEST IN FLIGHT!"
Old Aug 31, 2006 | 06:34 AM
jetdoc's Avatar
jetdoc
Mine too...It's fun to see an ego deflate!
Old Aug 31, 2006 | 06:41 PM
Greywolf's Avatar
Greywolf
"Canopy mechanism makes unfamiliar noise"
-I think this was an air force story...
The maintenance crew cycled the canopy on it open and closed for a while and then signed it off:
"Cycled canopy mechanism numerous times. Noise now familiar..."
Old Aug 31, 2006 | 06:53 PM
ivanribic's Avatar
ivanribic
Man some of those were killing me and I don't even fly.
Old Aug 31, 2006 | 08:54 PM
Mil1ion's Avatar
Mil1ion
and on the inside of the aircraft
On a Continental Flight with a very "senior" flight attendant crew, the pilot said, "Ladies and gentlemen, we've reached cruising altitude and will be turning down the cabin lights. This is for your comfort and to enhance the appearance of your flight attendants."
On landing the stewardess said, "Please be sure to take all your belongings. If you're going to leave anything, please make sure it's something we'd like to have."
"There may be 50 ways to leave your lover, but there are only 4 ways out off this airplane."
"Thank you for flying Delta Business Express. We hope you enjoyed giving us the business as much as we enjoyed taking you for a ride."
As the plane landed and was coming to a stop at Washington National, a lone voice came over the loudspeaker: "Whoa, big fella. WHOA!"
After a particularly rough landing during thunderstorms in Memphis, a flight attendant on a Northwest flight announced, "Please take care when opening the overhead compartments because, after a landing like that, sure as hell everything has shifted."
From a Southwest Airlines employee: "Welcome aboard Southwest Flight XXX to YYY. To operate your seat belt, insert the metal tab into the buckle, and pull tight. It works just like every other seat belt; and, if you don't know how to operate one, you probably shouldn't be out in public unsupervised."
In the event of a sudden loss of cabin pressure, masks will descend from the ceiling. Stop screaming, grab the mask, and pull it over your face. If you have a small child traveling with you, secure your mask before assisting with theirs. If you are traveling with more than one small child, pick your favorite.
Weather at our destination is 50 degrees with some broken clouds, but we'll try to have them fixed before we arrive. Thank you, and remember, nobody loves you, or your money, more than Southwest Airlines."
"Your seat cushions can be used for flotation; and, in the event of an emergency water landing, please paddle to shore and take them with our compliments."
"Should the cabin lose pressure, oxygen masks will drop from the overhead area. Please place the bag over your own mouth and nose before assisting children...or other adults acting like children."
"As you exit the plane, make sure to gather all of your belongings. Anything left behind will be distributed evenly among the flight attendants. Please do not leave children or spouses."
And from the pilot during his welcome message: "Delta airlines is pleased to have some of the best flight attendants in the industry. Unfortunately, none of them are on this flight!"
Heard on Southwest Airlines just after a very hard landing in Salt Lake City: The flight attendant came on the intercom and said, "That was quite a bump, and I know what y'all are thinking. I'm here to tell you it wasn't the airline's fault, it wasn't the pilot's fault, it wasn't the flight attendant's fault...it was the asphalt!"
Overheard on an American Airlines flight into Amarillo, Texas, on a particularly windy and bumpy day: During the final approach, the Captain was really having to fight it. After an extremely hard landing, the Flight Attendant said, "Ladies and Gentlemen, welcome to Amarillo. Please remain in your seats with your seat belts fastened while the Captain taxis what's left of our airplane to the gate!"
Another flight attendant's comment on a less than perfect landing: "We ask you to please remain seated as Captain Kangaroo bounces us to the terminal."
An airline pilot wrote that on this particular flight he had hammered his ship into the runway really hard. The airline had a policy which required the first officer to stand at the door while the Passengers exited, smile, and give them a "Thanks for flying XYZ airline." He said that, in light of his bad landing, he had a hard time looking the passengers in the eye, thinking that someone would have a smart comment. Finally everyone had gotten off except for a little old lady walking with a cane. She said, "Sonny, mind if I ask you a question?" "Why no Ma'am," said the pilot. "What is it?" The little old lady said, "Did we land or were we shot down?"
After a real crusher of a landing in Phoenix, the Flight Attendant came on with, "Ladies and Gentlemen, please remain in your seats until Capt. Crash and the Crew have brought the aircraft to a screeching halt against the gate. And, once the tire smoke has cleared and the warning bells are silenced, we'll open the door and you can pick your way through the wreckage to the terminal."
Part of a flight attendant's arrival announcement: "We'd like to thank you folks for flying with us today. And, the next time you get the insane urge to go blasting through the skies in a pressurized metal tube, we hope you'll think of US Airways."
A plane was taking off from Kennedy Airport. After it reached a comfortable cruising altitude, the captain made an announcement over the intercom, "Ladies and gentlemen, this is your captain speaking. Welcome to Flight Number 293, nonstop from New York to Los Angeles. The weather ahead is good and, therefore, we should have a smooth and uneventful flight. Now sit back and relax -
OH, MY GOD!"
Silence followed and after a few minutes, the captain came back on the intercom and said, "Ladies and gentlemen, I am so sorry if I scared you earlier, but, while I was talking, the flight attendant brought me a cup of coffee and spilled the hot coffee in my lap. You should see the front of my pants!"
A passenger in Coach said, "That's nothing. He should see the back of mine!"
BryanRR59
New Member Introductions
Apr 16, 2008 07:26 PM
rob_nc
Aug 15, 2003 03:51 PM
