ses light
Old Aug 30, 2006 | 11:40 AM
catman52987's Avatar
catman52987
Question ses light
I dont like the service engine soon light coming on and I would like to fix that. i know I need two pieces of rubber hose and a regulator but I dont understand about the wiring that I read about. if I just put in a regulator will that do any justice? can someone tell me what to do to install the map regulator (ie- what will I need and where it goes)
Old Aug 30, 2006 | 12:08 PM
nhancock's Avatar
nhancock
Are you referring to an overboost situation?
If so, look here for a kit. If you want to do it yourself, you can look at the install instructions and pretty much see what you need to get and where to put it.
http://www.itpdiesel.com/store.php?c...on=show_detail
Instructions
http://www.itpdiesel.com/other/Overb...structions.pdf
Hope this is what you were looking for.
Old Aug 31, 2006 | 07:36 PM
catman52987
I can get some hose and a regulator, but what do I do with the wiring?
Old Aug 31, 2006 | 07:47 PM
mech2161's Avatar
mech2161
If you use a regulator you don't need to wire anything.
Old Aug 31, 2006 | 07:52 PM
catman52987
Thanks for all your help guys, for some reason I thought there was wiring involved!
Old Aug 31, 2006 | 07:55 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
there are two different kinds. there is a mechanical one that has been posted about above (i have one), and there is an electronic way to bypass some sensors, that i wouldn't trust as much as a mechanical one that directly regulates the actual medium you want to control.
Hansolo99
May 19, 2014 08:59 AM
diesel-fitter-bum01
Apr 20, 2012 09:47 AM
897.3idi
Nov 3, 2011 10:12 PM
56-pickupman
Feb 6, 2007 09:38 PM
jtharvey
25
Jan 26, 2006 11:44 AM
