My new 2006 came with the upfitter switches but I'm having trouble locating the stubbed ends of the switched wiring. Does any one know where they are. The book tells one that they are around the fuse panel on the passenger side. I can't find them anywhere.
They are just behind the panel above your knee's on the driver's side. I would say close to your left knee. It is usually taped together and is right next to the big fuse block. Go to the Tech Folder and look at the High Idle Mod and you will see what the wires look like.
Thank you Tim: I found the link and It did the trick. I don't know why they havent put these type of switches in every truck made. They are so much better than all of the hack jobs and splicing that people have to do to add acessories.
