help using seafoam to treat engine
Old Aug 30, 2006 | 09:09 AM
sawblade's Avatar
sawblade
i have a 1999 ranger with the 4.0 and its has about 198,000 miles on it and it idles a little rough i put new plugs in it and the problem still seems to be there i have heard about seafoam and was wondering what is the best way to get it in the fuel system?
Old Aug 30, 2006 | 09:50 AM
eigenvector's Avatar
eigenvector
The gas tank?
Perhaps you mean intake manifold?
Old Aug 30, 2006 | 01:46 PM
fordboy_52's Avatar
fordboy_52
i would put a can in the gas tank with say a half a tank of gas. then i would buy the seefoam spray and spray it into the intake with the vehicle running. this helps release and break down carbon build up in the air system
Matt
Old Aug 31, 2006 | 03:14 AM
PW01's Avatar
PW01
I don't think I'd spray anything into the intake, I'd be worried about the MAF.
Old Aug 31, 2006 | 06:26 AM
pawpaw's Avatar
pawpaw
If you want to ingest the Seafoam through the intake side of the engine, use a vacuum line, like the brake booster line, stopped down with a smaller hose, with a "sports inflation needle" attached to that & inserted into the Seafoam.
Ths way you'll not likely have the engine ingest the Seafoam too quickly & hydrolock the engine & bend something up!!!!! lol
After this kind of treatment, you'll likely want to change the crankcase oil & filter & clean the spark plugs, as they'll likely be fouled up pretty good.
Now if your just looking to decarbon the engines intake valves & combustion chamber, using the Seafoam & not mess with the intake manafold runners & throttle body side of things, add the Seafoam to the gas tank, as has been suggested & run most of that out, but go for two or three spirited 20 mile or so, highway speed drives, on that tank.
That should clean the intake valves & combustion chambers, without dirtying up the oil & plugs so much.
If your of a mind to add the Seafoam through the air intake runner, so the throttle body gets some cleaning, be careful not to dirty up the MAF sensor, while ingesting the Seafoam.
If the throttle body is really dirty I think I'd consider removing it for a separate cleaning with "throttle body" spray cleaner.
Now you might find a tag from Ford that says, don't clean the throttle body, as it's upposed to have a coating inside that prevents it from sticking. Others have cleaned it anyway, with success, but were careful not to damage the coating.
Anything you choose to clean it or the intake runners with, should be chosen & used carefully, so you don't damage the TB coating, the composit material of the intake runners, or the O2 sensors.
There is a Ford "Decarboning" proceedure listed in the "Technical Info" thread, atop this forums main page.
It calls for using Motorcraft PM-3 to decarbon the engne, by intake side ingestion, with the same hydrolock cautions & oil & filter change & spark plug cleanig afterwards.
Another "clean type" intake valve/ engine decarbon option, for consideration, might be a tank of Texaco or Chevron gas, with a bottle of Techron Concentate added, run most of that tank out, while doing the above spirited highway drive cycle.
Techron is a very good intake valve & combustion chamber cleaner upper!!!! imo
Just some additional thoughts to ponder.
PStruwing
Dec 9, 2012 03:02 PM
flaresideman
Oct 3, 2010 11:39 PM
cjsimp1
1997 - 2003 F150
Jan 28, 2009 02:48 AM
zhavener
Jan 22, 2008 09:50 AM
leftnutt34
Aerostar
Oct 6, 2004 08:38 PM
