rough clutch
Old Nov 25, 2001 | 06:34 PM
robber1's Avatar
robber1
Post rough clutch
When I start out in first gear the truck shutters real bad. At first it only happened when the truck was hot, now it happens all the time.
'64 F100 223 c.i. three speed
Old Nov 25, 2001 | 08:19 PM
glindley's Avatar
glindley
rough clutch
Sounds like yer gonna have to replace the clutch (pressure plate, disk, throw-out bearing and maybe even the pilot bearing). Approx cost $100. Does it shake your teeth out when you let the clutch out in reverse?
Gene (64-223, 3 on the column)
Old Nov 25, 2001 | 10:23 PM
Rosati's Avatar
Rosati
rough clutch
Before spending all that money, try adjusting the clutch first. It isn't hard just crawl under there and give it a try. It should get you a few hundred more miles.
Krosati
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Nov 26, 2001 | 05:41 AM
robber1's Avatar
robber1
Post rough clutch
yes, major roughness in reverse
Old Nov 26, 2001 | 07:37 PM
glindley's Avatar
glindley
rough clutch
I have not been able to adjust out the "chatter" that Krosati speaks of, but I suppose it is worth a try. Mine has "chattered" for quite some time. When I did my "clutch" job quite a while ago, I only replaced the disk, as I was short on cash and the Pressure plate did not appear to be that bad. It fixed it for a short time, but it went back where it was. I am up for a total clutch job this time. Plus I am gonna have the fly wheel machined as well.
Gene
Old Nov 29, 2001 | 07:37 PM
MatthewB's Avatar
MatthewB
Post rough clutch
I had the same problem.Replaced all parts except trans input shaft bearing,didn't completly fix the problem.Next I replaced the motor and trans mounts,Fixed.
Old Nov 29, 2001 | 09:11 PM
jowilker's Avatar
jowilker
rough clutch
Fred you may need to learn to release the clutch sooner. I think sometimes the chatter is caused by higher revs of the engine while slowly releasing the clutch. Now once it has gotten to the point that you describe replacement is the only answer.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 15, 2002 | 02:02 PM
Trail_Rider's Avatar
Trail_Rider
rough clutch
What usually causes this clutch chatter, is overheating the clutch. Most notably on high geared setups which is compounded by tall tires. The short term fix is a complete clutch job including turning the flywheel. However, if you're running alot of heavy traffic (stop and go), of hauling alot of weight often where you need alot of clutch slippage to get rolling, it's only going to be a matter of time before it's back.
Trail Rider
Old Feb 15, 2002 | 03:24 PM
44dwarf's Avatar
44dwarf
rough clutch
Tarster
6.2L V8
34
Nov 15, 2018 04:45 PM
Bobbys Big Red Rig
Nov 23, 2013 10:16 PM
Plums72
Jun 25, 2007 06:19 PM
jpfelock
Oct 18, 2006 08:17 PM
RangerWoman
Jun 29, 2003 04:57 PM
