Old Aug 29, 2006 | 03:17 PM
460mudtruck's Avatar
460mudtruck
i have picked up an 86 460 out of a f-350 motor home for a very good deal $125 for the whole thing with a 4 core rad,trans cooler,an edelbrock 750 and headers. I was woundering if this is a good motor like what kind of heads and what will wake it up for not a alot of money
Old Aug 29, 2006 | 08:09 PM
turbo2256d's Avatar
turbo2256d
Port the heads you have now and dont change anything else. You will have to richen the carb a bit.
Old Aug 29, 2006 | 09:09 PM
monsterbaby's Avatar
monsterbaby
Well you might want to put in a double roller or early model timing chain to get the cam timing straight up. (said both double roller and early model as it seems all the aftermarkiet double roller stuff has gone with one part number for both early and smog model engines)
Old Aug 30, 2006 | 08:39 AM
William's Avatar
William
Geeze, the carburetor is worth more than you paid for the engine!!! Lucky you!
Old Aug 30, 2006 | 10:49 AM
turbo2256d's Avatar
turbo2256d
Should ask what are you going to do with it? Your goal?
Old Aug 30, 2006 | 07:20 PM
460mudtruck
im putting it in a 79 ford with a 4"lift and a 3" body lift with 39.5 its pretty much for the mud and offroading
Old Aug 30, 2006 | 07:22 PM
460mudtruck
ya i got the whole motorhome for 125
Old Aug 31, 2006 | 12:22 PM
460mudtruck
were is a good place to get the double roller or early model timing cain
Old Aug 31, 2006 | 12:29 PM
monsterbaby
Jegs is a site sponser, or you can get it from any number of the site sponsers or your local auto parts store.
Old Aug 31, 2006 | 04:52 PM
460mudtruck
is the cloyes part # 220-9-3122 for 68-71 will that be a good choise or do you suggest something else
Old Aug 31, 2006 | 04:55 PM
monsterbaby
Yes that one will work, Jegs still lists it as 68-71 but cloyes just says it's for all of them now. Basically cloyes and most of hte other companies that make the double roller timing chains figured out anyone wanting to go with a roller timing chain wants teh early set anyway so just make one part number for all of them.
DarkOverCast
Mar 1, 2017 10:44 PM
Brnfree
Aug 3, 2016 09:06 PM
Scott3483
May 7, 2015 08:01 AM
badblu86f250
13
Sep 20, 2011 11:47 PM
powerstroker100
Nov 23, 2010 04:54 AM
