Lets talk Tilt!
Old Feb 23, 2002 | 05:10 PM
66ranger's Avatar
66ranger
Lets talk Tilt!
I have found a tilt column from a '79 Bronco that I am pondering buying. I noticed that the Bronco column attaches via a u-joint type setup to the Bronco 4x4 steering. Is there any way to attach this Bronco column to my (non-bendix) '66 Power Steering truck using the regular rag joint method? Another non-tilt '79 pickup in the same junkyard shows the same lower column end, but with a regular type steering shaft attaching to the rag joint. ALSO are the splines the same on the tilt column as on the regular ones? I would like to use my stock steering wheel. All comments would be welcome. The
non-cruise tilt column can be mine for $ 60 but wouldn't be worth anything if I can't use it in my truck!
Old Feb 23, 2002 | 07:05 PM
fomocoloco's Avatar
fomocoloco
Lets talk Tilt!
60 dollars is cheap. they regualarly bring 150. i also am installing a tilt wheel in a 66 and the rag joint will work with no problem. i found a tilt column on ebay with a factory rally wheel and paid about 200. i am very happy with the rally wheel appearance. i don't know about using the factory wheel with the tilt column however. i am sure someone on here has done it or tried it. i just started removing a 70 429 that was installed in a 79 f250 supercab. it has a tilt column with cruise control. tomorrow i will finish removing the engine and then the tilt column and the cruise control stuff so i have an extra tilt column with cruise. good luck with your project. jim.
Old Feb 24, 2002 | 10:54 AM
jowilker's Avatar
jowilker
Lets talk Tilt!
I have a couple of tilts that I am making ready for my trucks. First you won't be able to use the 66 vintage wheel on that column the mating plates just under the wheel are very different. The 66 era is much smaller. I don't much about 4X4 columns (their lengths how they connect differently) but I imigine it wouldn't take mucj to make it work. I had an incomplete tilt from a 78 F150 and was able to get one from a van and cut 6 1/2" out of the shaft and use it in the 150 column to make it work. Hope you can make yours work.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
truckfarmer's Avatar
truckfarmer
Post Lets talk Tilt!
67crewcab154
Nov 23, 2012 05:05 PM
FordEdselFanatic
Apr 19, 2009 04:30 AM
ford-nut
Feb 25, 2005 07:35 PM
rlh
1978 - 1996 Big Bronco
Nov 4, 2003 09:47 AM
66ranger
Nov 5, 2001 08:53 PM
