How much do they wiegh?
Old Aug 28, 2006 | 07:19 PM
marlin39d's Avatar
marlin39d
I have read that in 2004 the F-150's had a significant wieght gain along with all the other changes that came along that year.
I recently test drove two new SuperCab trucks with one having the 4.6 and the other having the 5.4 and both had 3.55:1 gearing in the rear-end. I was amazed at the lack of acceleration especially in the one with the 4.6 engine. All I have to compare it to is the excelleration on my father's truck which is a 1997 SuperCab with a 4.6 and also has a 3:55 rear-end. His '97 truck feels like it has much better excelleration. So I'm assuming all of this is due to the extra wieght the newer ones are lugging around.
So does anyone know approximately what the curb weight is on a 2006 SuperCab w/6.5' bed?
And what about a Regular Cab's w/6.5' bed's weight, any ideas on it since I haven't ruled that truck out completely when I buy?
Old Aug 28, 2006 | 07:34 PM
FordTruckGuySTX's Avatar
FordTruckGuySTX
05 single cab shortbed 4x4 4.6 auto with my toolbox in the back, sub/amp and me in it weighs right at 3 tons
Old Aug 28, 2006 | 07:49 PM
marlin39d's Avatar
marlin39d
So now the question is how much more does 4WD wiegh over a 2WD?
Old Aug 28, 2006 | 08:06 PM
smokestone52's Avatar
smokestone52
06, Scab, 5.4, 4X4, short bed(5.5), 3.73, Heavy because it is a Lariat.
13.8 mpg city, I drive hard. 17.9 highway pulling a 2300 lb camper.
I can burn rubber all day long in this truck. I barely give the pedal anything and I zoom most on the ramps. Pedal to the metal, hang on brother you might hit the guy in front of you.
No, Sir! my F-150 is fine. Did I say FINE!
Maybe you don't talk well of your truck, so it don't perform well for you! Happy Ford Trucking!
Old Aug 28, 2006 | 08:11 PM
smokestone52
Oh, on another note. Yes the new F-150 is heavy. The only thing I wonder about is the brakes. Man those look like puny brakes for such a fast, and heavy truck! Time will tell!
Old Aug 28, 2006 | 08:14 PM
Abaddon's Avatar
Abaddon
I have a 04 screw 4x4 larait and it weights in at 6,000 lbs or pretty dang close to it. But for accelration it seems good to me I can smoke the tires but dont do it that often since I dont want to buy new ones anytime soon.
Old Nov 1, 2006 | 05:58 PM
superstar555's Avatar
superstar555
Did you order this truck? I can't find a '07 Scab Lariat 4x4 SB ANYWHERE!
All the dealers have is the Screw.
Old Nov 1, 2006 | 06:16 PM
marlin39d's Avatar
marlin39d
I put my '06 F-150 SuperCab XLT 5.4L 2wd on the scales today...5350 Lbs. w/26 gallons of fuel and no driver or load of any kind.
Makes me kinda' wonder what an F-350 diesel dually with crew cab and 4WD would weigh?!?!
Old Nov 1, 2006 | 06:38 PM
Catdave's Avatar
Catdave
That's not too bad- I had an '04 Silverado Z71 ext cab 4x4 that weighed in at 5220 with 1/2 tank gas & no passengers.
Haven't weighed my 5.4L '06 XLT SCrew 4x4 yet...
Old Nov 5, 2006 | 10:50 PM
Carguy1959's Avatar
Carguy1959
My 04 Fx4 SCAB weighed in at 5760 pounds with a 1/2 tank of gas...
Old Nov 6, 2006 | 01:22 AM
Tango2020's Avatar
Tango2020
Weight isn't your problem. I own an 04 4x4 with a 4.6. Yes..when you drive it the truck feels like you are towing a 5000 pound trailer behind it but it is due to Ford tuning it down for whatever reason. I put an Edge tuner on it 2 weeks ago and its like going from a Ford Pinto to a Mustand GT. I would sell this truck if I had to give up my Edge tuner. You will be amazed.
Old Nov 6, 2006 | 01:37 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
these babies are heavy. I drove my 94 F-150 today after driving the 06 for 2 weeks. I had gotten used to giving the 06 a liberal amount of throttle and zooming off. I did the same in my 94 and roasted the tires before I realized what I was doing.
The 5.4 liter is a powerful motor and when coupled with the 3.73 gears, I've got lots of giddy-up and go. It does however take a little bit to get her moving.
Old Nov 6, 2006 | 01:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
oh yeah, I've noticed a common thing here for the 04 owners. The majority say the truck is underpowered and sucks gas like a hog. I think Ford must have done some reprogramming since then, because my truck (06 SuperCrew FX4 5.5ft bed with 5.4L) has plenty of power.
hopefully someone out there has the same truck as me and has weight tickets. I'm interested in what she weighs myself.
Old Nov 6, 2006 | 10:19 AM
the4by4freek's Avatar
the4by4freek
Hey Tylus, I have an 04 Lariat Screw 4x4. It isn't a gas sucking hog and it has plenty of power. I think the biggest thing is that the owners of the 04's didn't go and get the re-flash from Ford. It made a night and day difference. That plus the Edge EVO and hold on to your hat! It will roast the tire right off the rims if you're not careful. MPG is respectable at 18MPG highway and 15MPG city. IT will get less if the throttle is heavily manipulated by your right foot!
Old Nov 6, 2006 | 12:44 PM
marlin39d's Avatar
marlin39d
What do you mean by the "re-flash" from Ford. I'm assuming it's the resetting of the factory computer by Ford. Close???
Do you think an '06 could benefit from a re-flash? What would they charcge to do it?
