Sponsored by: Auxito
Backend Vibration when Accelerating
Old Aug 28, 2006 | 04:02 PM
Hartwa's Avatar
Hartwa
Hi..
I have a F150 SC with a 5.4L and 4WD. I notice that after I have been running it a long time, like 2 hours or more, the back end shimmeys quite a bit when I come off a stop and start to accelerate. It does'nt do it through out the whole acceleration just the very beginning (maybe 1 or 2 seconds) and I never feel anything when I am up to speed.
I also noticed a lighter version of this when I start up the truck and have to make a turn at the same time I am beginning to accelerate. It diffenatley seems to be more severe the longer the truck has been running.
Any things to try or check?
Hartwa
Old Aug 28, 2006 | 04:37 PM
92merc's Avatar
92merc
Lube the slip yoke on the drive shaft.
Old Aug 28, 2006 | 07:30 PM
Canadian Screw's Avatar
Canadian Screw
Had the same problem with my supercrew 4x4. Turned out it was the clutch packs for the LS rearend. Runs great know. Can't beleive I drove it so long with the vibration. Hope this helps.
Old Aug 29, 2006 | 10:44 AM
Hartwa's Avatar
Hartwa
Thanks...I'll try that. Seems like a potential low cost solution.
Old Aug 29, 2006 | 10:48 AM
Hartwa's Avatar
Hartwa
Thanks for the help. What is the "LS" (left side???)? What did this cost you? Did you have it serviced or do it yourself.
Old Aug 29, 2006 | 11:09 AM
Bdox's Avatar
Bdox
Limited slip differential. If you have one, change the oil and use the recommended additive.
Also, after a run feel your rear u-joint. If it is noticably hotter than the driveshaft, it's shot.
Old Aug 29, 2006 | 01:10 PM
F150&EB's Avatar
F150&EB
Thumbs up
I had the same thing happen with my '01 4x4. It only happened on long trips. Took it to the dealership and they added some "friction modifier" additive. The service manager told me Ford doesn't put enough in from the factory. No problems since.
That's the only time in my truck's 91K miles that it's been to the dealership.
Kgonzo23
Aug 30, 2016 06:30 AM
Danner717
Sep 20, 2015 08:48 PM
Hartwa
6.7L Power Stroke Diesel
28
Apr 2, 2015 06:49 AM
Hartwa
Mar 5, 2014 09:30 PM
Hartwa
1997 - 2003 F150
Jan 22, 2007 03:27 PM
