hesitation/miss durring acceleration
Old Aug 23, 2015 | 11:19 PM
Danner717's Avatar
Danner717
Question hesitation/miss durring acceleration
Hello everyone! Not sure what's going on here or really how to explain it clearly. My truck is developing a hesitation or a miss when accelerating. It only does it in the beginning of accelerating like when just starting off from a stop. Seems like its more noticeable with the more I get on it. If that makes any sense. When just lightly accelerating it doesn't do it, like going slow through town from light to light. But when I give it more is when I feel it. It seems like it only does it before the turbo kicks in and it puts out a little smoke too only before turbo kick in. After that it runs good with no noticeable miss or anything. WOT runs feel good after it clears up. Its just when first starting out with anymore that 1/4 throttle I can feel it. Does something need cleaned?
Old Aug 23, 2015 | 11:37 PM
04badford's Avatar
04badford
I Noticed you have the Cat Delete, is the EGR Delete also? If not may be time to pull it and clean up the soot. Try not to get cleaner in the electrical ports.
Old Aug 23, 2015 | 11:39 PM
04badford's Avatar
04badford
While your in there cleaning get the MAP threaded nipple to the Intake, and IAT2 sensor those will be sooted up as well
Old Aug 23, 2015 | 11:55 PM
Danner717's Avatar
Danner717
That's the only thing deleted. Everything else on the motor is still stock. All the EGR stuff is still there for now. I'm new to all this so any tips and pointers would be greatly appreciated. I do know where the EGR valve is but never took it out. The other things you mentioned I've heard people talk about them but this is all new to me.
Old Aug 24, 2015 | 12:05 AM
Danner717's Avatar
Danner717
Ive also heard someone mention before in other threads that the EBP sensor or tube needing cleaned sometimes. Where's that located? Sorry if I sound dumb but I'm new to all this and trying to learn about my truck.
Old Aug 24, 2015 | 12:37 AM
04badford's Avatar
04badford
No worries , FTE is a great site to learn , the EGR Valve need a 8 mm socket you want to twist counter clock wise and pop it straight up , if sooted in the valve will be a bugger to get out I use two thin flat bars in my album you can see what there are, use carb cleaner to spray it off be carefully not to get the small hole under the gasket or top side Electrical lightly move the two discs hold down ward and spray , I usually have a sock wrapped around the areas mentioned, the IAT2 sensor is located behind the upper fuel bowl, usually this sensor is over looked and will be caked , I use a plumbers flux brush to help knock the soot out, the MAP Sensor is located on the passenger heater Ac box with 3 nuts holding the sensor, you won't have to clean the sensor just follow the hose down to the Intake unhook the hose from the sensor to help unthread the nipple I be leave a 10 mm wrench use air to blow it out then carb cleaner , the intake make sure the little hole is clean too. EBP sensor is located on your truck year Thermostat housing bracket . First if you want to take it off spray WD 40 on the threads both ends of the metal tube and let it sit for a while before .braking them loose , you can use weed eater line to clear the tube all the way , and ( don't Spray the sensor) just make sure the hole is clear/ open. I would do one at a time starting with the EGR Valve and see how it runs then do the others the PCM will throw a EGR Code because it was disconnected . Might want to try and receive a code before you start the process.
Old Aug 24, 2015 | 01:21 AM
Danner717's Avatar
Danner717
Thanks for your help. Seems like I get quicker and more helpful answers on here compared to powerstroke.org. What do you mean about that last part? You mean I should wait till I get a code before I clean anything.
Old Aug 24, 2015 | 02:38 AM
Yahiko's Avatar
Yahiko
I think he is saying to only make one change at a time and go drive it between
so that you know what thing fixed the problem.
Also having something like the scanguage 2 of one of the ELM devices is
a really good way to keep an eye one things.
Sean
6.0L Tech Folder
Old Aug 24, 2015 | 03:01 AM
Danner717's Avatar
Danner717
Sean
6.0L Tech Folder
OK thanks and I do use torque pro with my 7 inch tablet
Old Aug 24, 2015 | 06:48 AM
WatsonR's Avatar
WatsonR
Watch VGT and see what's happening with the turbo. That is the commanded value, but if it's commanded and never reached, it should continue to command more. May need cleaning due to sticking vains, maybe why it takes a few seconds to catch up.
Old Aug 24, 2015 | 09:15 AM
04badford's Avatar
04badford
Thanks guys , I wanted to keep it simple until things were checked off , then hit the big ticket Idems , like turbo, ICP so on , take a look in the Tech Folders under 6.0 bible Sensor parts location , lots to read and get familiar with your truck.
Old Aug 24, 2015 | 01:35 PM
lupuseven's Avatar
lupuseven
Not to rule out all the above just more food for thought.
Additionally if you stomp on the pedal the computer doesn't like it. and wont let you give it full throttle. Its possible that could be your issue, for the hesitation. Smoke could also just be when the computer finally gives in and "slowly (milliseconds)" allows the rapid acceleration, which in turn will still give it to much fuel hence the black smoke.
to combat the this I found from a stop when I want to romp on it, go 50% pause 100% and it does fine. take a few time to get used to it but just habit now
Old Aug 24, 2015 | 10:25 PM
Danner717's Avatar
Danner717
VGT is one of the PIDs I have displayed on torque pro. What should I be looking for?
Old Aug 25, 2015 | 06:56 AM
WatsonR's Avatar
WatsonR
15% or 85%
Values that don't change or really slow to change. You should be able to get a turbo fart, if not, that could indicated sticking/stuck vanes. It's the black cloud and then the turbo kicks in.... meaning it's dumping the fuel to it when you stomp it but the turbo isn't providing enough air.
Old Aug 25, 2015 | 10:57 PM
Danner717's Avatar
Danner717
15% or 85%
I think it probably does need cleaned, I'm not sure when it was done or if it ever was by the previous owner. So that could be part of the problem but I can make it fart I usually see it change quite often. it will usually do the vane sweep from 15 to 85 when at idle but sometimes it doesn't and it is constantly changing when I'm driving depending on throttle position.
