water passages
Old Aug 27, 2006 | 10:52 PM
64Shortie's Avatar
64Shortie
water passages
I'm working on the 429 block right now prepping it for a rebuild and was wondering if the is a method/tool/cleaning agent for clearing out the water passages.
Old Aug 27, 2006 | 11:21 PM
airharley's Avatar
airharley
Bottle brushes, long thin flt head screw driver, or just take it to a place to have it hot tanked. The water passages are a pain to manually clean out. On my engine I used a Prestone flush kit with a little added CLR to kick it up a notch. I used it right after the cam was broken in.
Old Aug 27, 2006 | 11:26 PM
64Shortie's Avatar
64Shortie
Sweet, just out of curiosity when you get the block hot tanked will they strip the block to bare metal as well?
Old Aug 27, 2006 | 11:31 PM
airharley's Avatar
airharley
The chemicals involved will do it. You may want to ask for it to be shot peened as well. I don't have an indepth asnwer for what shot peening is but it is kind of like sand blasting it but with metal *****.
Old Aug 28, 2006 | 09:06 AM
460me's Avatar
460me
Have it hot tanked,they will pull all the oil plugs off also.
Old Aug 28, 2006 | 09:24 AM
64Shortie's Avatar
64Shortie
rebuild
Cool, while were on the topic of machine shops, and rebuilds, I was wondering if there are any kits that I should look out for? I'm pretty muck building back to stock, with the exception of the intake and carb. I'm looking at a master kit from larrys performance out of L.A. for $469 which seems like a pretty good deal but I don't want to be rebuilding it again anytime soon.
Old Aug 29, 2006 | 05:20 AM
turbo2256d's Avatar
turbo2256d
There are shops that can bake the block clean it will come back looking like a new casting. If you find one of these places tape up the block and paint it as soon as possible before oil and rust starts geting in the metals poors.
Old Aug 29, 2006 | 01:20 PM
airharley's Avatar
airharley
Well before you buy any kits have the block cleaned and checked for bore size. Nothing sucks more then returning a kit because you guessed. I know you are planning to rebuild back to stock but you may want to take the time now to go through and do a few upgrades to the short block while it is apart. Most of them are relatively cheap to do as well. For instance replacing the main bolts with studs. Just little things that will allow you to play with the upper end later if you feel the speed bug.
dylansf23
Mar 18, 2015 05:58 PM
kedwinh
Oct 11, 2011 05:28 PM
hoxiii
Nov 23, 2006 11:11 AM
xfordman
Apr 29, 2005 01:29 AM
EdC351M
Aug 5, 2002 11:07 AM
