95 PSD Wiring Question
Old Aug 27, 2006 | 06:47 AM
Peter A's Avatar
Peter A
Unhappy 95 PSD Wiring Question
While doing some repair work, I lost the "Pin-out" to the solonoid mounted on the Passengers fender adjacent to the surge tank. Could some one please take a look at their truck and give some help here?
Thanks in advance,
Pete
Old Aug 27, 2006 | 04:59 PM
Franklin2's Avatar
Franklin2
Are you talking about the starter relay (solenoid)? I do not have a 95 PSD, but Ford used a lot of the same colors through the years.
Do you have a red/blue wire? That should come from the neutral start switch and will connect to the small terminal on the relay.
Then you should have the two large terminals left. One will go to the battery +, and the other large terminal will go to the starter.
Then yo umay have a smaller wire left left over that has a large terminal ring on it, and it may be yellow? If you do, this will go on the large terminal connected to the battery +.
If this is not correct, write back in with what wire colors and sizes you are dealing with.
PEI
Apr 12, 2015 07:27 AM
Ken Ishmael
1997 - 2003 F150
Jul 10, 2014 11:39 PM
SgtDan
Arizona Chapter
May 3, 2010 09:24 PM
grey1169
Apr 13, 2009 01:48 PM
whiskey26
New Member Introductions
Nov 20, 2008 09:45 PM
