1978 - 1996 Big Bronco
Loose pitman arm?
Old Aug 26, 2006 | 02:56 PM
dichdoc's Avatar
dichdoc
Loose pitman arm?
The arm that comes off the steering box seems to be loose up and down (maybe 1/8"-3/16") but seems tight side to side is this normal or not?
Old Aug 26, 2006 | 07:20 PM
tom2131968's Avatar
tom2131968
No I don't believe that it is but since the shaft is tapered all you need to do is to tighten the bolt. I believe that the torque spec is over 100 lbs for that nut, BTW.
Old Aug 26, 2006 | 11:42 PM
chrono4's Avatar
chrono4
no, there should be no play in the arm, you can try tightening it, and if that doesnt help then the box/sector shaft or the arm needs replaced.
Old Aug 27, 2006 | 02:19 AM
HUCKSTER-USA's Avatar
HUCKSTER-USA
Yea If The Shaft Seems Loose Too, (wiggling) Should Be Leakn No? If The Shaft Is Tight And The Arm Is Loose, Tightn Or Replace Asap!
Old Aug 27, 2006 | 10:30 AM
tom2131968's Avatar
tom2131968
Do you have a lot of play in the steering? Anyway, if the arm just seems looose, try to tighten it first. Stage two would be to replace the box and since your truck is a '78, it might be aboiut time.
Old Aug 31, 2006 | 09:06 AM
dichdoc's Avatar
dichdoc
I do have very sloppy steering and found the loose arm while checking everything the book said to check. the steering box does seem to be weeping out of the top (the opposite side of where the the arm bolts on). Is the steering box available from a parts place and anyone have a ball park price?
Old Aug 31, 2006 | 09:00 PM
tom2131968's Avatar
tom2131968
about 150 with a core charge of about the same. Not too bad of a job though you need a pitman arm puller. Helps to have a second set of hands but I did it by myself in about 1.5 hours and in no rush. I got mine from autozone and am extremely happy with the results.
My1964ford
Dec 25, 2016 10:20 PM
mlandrum51F1
Feb 18, 2016 05:10 PM
Road Warrior 95
Jul 5, 2014 09:55 AM
Kickinbass23
Aug 5, 2010 02:47 PM
nicheff
Modular V10 (6.8l)
Apr 14, 2010 06:16 PM
