Offroad & 4x4
Regearing D44
Old Aug 25, 2006 | 02:16 AM
74fordtruck's Avatar
74fordtruck
Regearing D44
There shouldnt be a reason why I couldnt slap a set of 4.10's on my factory 3.50 carrier is there? I understand what's involved in setting up the gears, but as far as the different ratio'd R&P's on the 3.50 carrier shouldnt be a problem, right? THANKS!!!
Old Aug 25, 2006 | 02:24 AM
FordPickup460's Avatar
FordPickup460
You need a 3.92 and numerically higher carrier
Old Aug 25, 2006 | 02:35 AM
74fordtruck
would my spiders fit into one of these?
http://broncograveyard.com/bronco/i-..._93_and_up.htm
Sorry about the tech thread in the NWC. I HONESTLY meant to post it into the 4x4 section, but being 12:30am, i mixed up the 63 and 89 in the address i guess.
Oh, and the rig's a 76 F100
Old Aug 25, 2006 | 10:54 AM
fordraceboy's Avatar
fordraceboy
44 spiders are all the same, the difference in the carriers is the thickness of the ring gear mounting flange IIRC..
Old Aug 25, 2006 | 12:20 PM
74fordtruck
What about a carrier from a D44 low pinion (highboy) or a chebby/dodge? What about the carrier from a rear end dana 44 (such as a jeep or something?)
Old Aug 25, 2006 | 02:12 PM
fordraceboy
i THINK the carriers are all the same... it doesn't seem to matter what the gears are going in when you buy them- unless it's a high pinion. i've used chevy spider gears in my highboy with no problems, and put front 44 gears in the rear 44 on an old 55 F100 I used to have... alot of words here but no clear answers- yep: normal for me... LMAO
Old Aug 25, 2006 | 06:13 PM
beeboy's Avatar
beeboy
remember, little grasshopper...the HP D44 uses reverse cut gears.
Bob (oldhalftons) has a magazine of mine that has an article on regearing the D44. Might see if he can get it to you this weekend.
Old Aug 25, 2006 | 07:30 PM
Ford_Six's Avatar
Ford_Six
Hang on, my brain is a little slow today-
You need a high pinion D44 gearset and carrier for a 4.10 ratio-
I happen to have just such a setup sitting in the front of my 72. If anybody from this area is driving a truck or car out there (I don't want to throw this at Chris on his bike), I can pull it tonight and have it on it's way tomorrow.
Kerry, are you going?
Old Aug 25, 2006 | 11:44 PM
74fordtruck
You got yourself a buyer here Jared.
KERRY!!!!! WHERE ARE YOU?!?!?!?!?!
Otherwise, I doubt shipping would be TOO unreasonable. I'd be payin shipping no matter which way I guess.
Old Aug 26, 2006 | 12:57 AM
kspilkinton's Avatar
kspilkinton
Sorry guys... I'm not hitting up Ivan for a place to sleep. I've got scout stuff in our neck of the woods tomorrow.
Sorry, Scooter.
-Kerry
Old Aug 26, 2006 | 01:00 AM
Ford_Six's Avatar
Ford_Six
Either way. I might potentially be a bit busy tomorrow with a run up to Bellingham, but that won't be until in the afternoon. It'll probably take me about an hour to pull the gears, the axles are already out of it. If nobody can take it, i'll pull it and box it up on Sunday.
Old Aug 26, 2006 | 01:28 AM
hotrod_ta's Avatar
hotrod_ta
I can't swing the cash to make a trip up there for the drunken stupor, I mean BBQ. Navy screwed up my paycheck and shorted me almost 300 bucks last paycheck... So I'm going to be home nursing a sore wallet for the next week... That and I need to get my buddies cars done so I can get my truck back...(long story)
Old Aug 26, 2006 | 02:04 AM
Ford_Six's Avatar
Ford_Six
When's the next time Steve will be around?
I have the head almost all cleaned up, as soon as the gasket set gets here it can go back together.
Old Aug 26, 2006 | 10:08 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
No probs...
Old Aug 26, 2006 | 11:15 AM
monsterbaby's Avatar
monsterbaby
May I make a suggestion unless you have a press or access to a press it might be cheaper to have someone else setup your gears. It's not that I am saying you couldn't do the setup, it's the fact that you end up pressing bearings on and off sometimes several times (ask Ivan about that) and if your paying a machine shop each time it gets real expensive real quick, I figure my press paid for itself by about the second gearset I setup with it.
