Interior lights shutoff
Old Aug 24, 2006 | 09:37 PM
puppypower's Avatar
puppypower
I know the lights have a time delay to shutoff when the doors are shut. My question is, is there a way to shut off the lights when the rear door or glass window is open for a long period of time? Its not too fun fending off bugs at a drive-in movie at night with the kids.
My idea was to put a toggle switch inline with the interior light circuit to kill the lights when needed. I just wanted to put this out here to see if anyone had a better idea.
Oh yeah one more thing. The ignition switch was in acc to allow use of the radio. Thanks for the help.
Old Aug 24, 2006 | 09:56 PM
PAPPYBALL's Avatar
PAPPYBALL
Not sure about other years but on mine, (2003) all you do is spin the dimmer switch all the way in the down position. It will click when all the way in the down position similar to when you turn your interior lights on by spinning the dimmer up, and it will shut all interior and courtesy lights off no matter what doors are open.
Old Aug 25, 2006 | 07:38 AM
puppypower's Avatar
puppypower
Thanks for the reply. I have aready tried the dimmer switch. It would be nice if mine functioned that way but it doesn't. I have a 2001 xlt 4.6l 4x4.
Old Aug 25, 2006 | 07:45 PM
EagleDakota's Avatar
EagleDakota
My 2000 EB has a "battery saver" trick. If the doors are left open for 20 minutes, the lights go off.
Old Aug 25, 2006 | 09:04 PM
puppypower's Avatar
puppypower
The lights stayed on the entire movie. I hoped they would shut off after a short while. But they didn't. I think because the switch was in acc position, it allowed the lights to stay on. I will figure something out this weekend.
Old Aug 26, 2006 | 11:00 AM
amm888's Avatar
amm888
puppypower, i believe there was a rather indepth thread about someone putting in a toggle switch for the same exact reason as you: trying to watch a drive-in movie. i can't recall the details, but maybe a search under "drive-in" will bring it up.
al
Old Aug 26, 2006 | 11:04 AM
amm888's Avatar
amm888
check these out:
https://www.ford-trucks.com/forums/9...r-gate-up.html
https://www.ford-trucks.com/forums/2...nterior+lights
Old Aug 26, 2006 | 10:26 PM
puppypower's Avatar
puppypower
Cool, thanks for the help. I'll wire in the switch tomorrow.
Old Aug 27, 2006 | 08:56 AM
puppypower's Avatar
puppypower
Finished wiring in the switch. Was no problem getting it in. I put it in the rear arm panel where the seatbelt attaches to the frame on the driver side. The panel had a flat spot right under the seatbelt anchor, like it was made for a switch. Everything works perfect. Thanks for the help. Chris
Old Aug 31, 2006 | 10:58 PM
austinjorg's Avatar
austinjorg
I would just like to know where there is still a drive-in movie!
Old Sep 1, 2006 | 08:59 PM
puppypower's Avatar
puppypower
Up in the northeast. It's pretty cool. You get two shows for the price of one in a regular movie theater. So I was fighting bug for 4 hours, that sucked. Plus I was the only idiot with my lights on. I felt like I was standing out like a sore thumb.
Old Sep 14, 2006 | 07:08 PM
Daviddc114's Avatar
Daviddc114
does this fix work for both the rear door and glass or just the door itself???
Old Sep 14, 2006 | 08:03 PM
puppypower's Avatar
puppypower
It worked for the glass and door. So you can run around with the rear window up.
Old Sep 17, 2006 | 10:16 AM
Daviddc114's Avatar
Daviddc114
heyy??? I looked at the wire harness in the drivers side pillar.. at the bottom behind the seatbelt and i did find 2 harnesses, a small one and a large one on the bottom.. the small one is the only one in the door pillar.. there was no purple and white wire?? Could it be a different wire???
i have a 2000 eddie bouier 4X4
Old Sep 18, 2006 | 02:50 AM
Daviddc114's Avatar
Daviddc114
never mind... got confused because everyone was calling it drivers side pillar when actually it was the drivers side rear quarter trim... all good... hooked it up, works awsome!!
Chris74
Nov 16, 2014 01:13 PM
Steves55
27
Jun 21, 2010 06:14 AM
neilc88
Dec 8, 2007 11:55 PM
Bud Man
Apr 24, 2007 03:20 AM
brwnk1
Oct 25, 2002 04:31 PM
