oil problims
oil problims
Hi all:
I had my stock heads milled and now the passages thst the oil flow in are
checking .110 deep.
The big book says they should be around .2. so do i leave them alone and not install the oil restrictors on the top side? or take the dremmel to the 2 passages and in stall restrictors?? what do ya think ?
checking .110 deep.
Before you clean up the heads tap the angled passage under the rocker stand on each head at the oil feed to 3/8"-16 thread. Later if needed you can install allen grub screw restictors drilled in different diameters to match your needs. A lot cleaner than installing Holley carb jets. They first must be annealed before drilling but worth the extra effort later.
.....=o&o>.....
.....=o&o>.....
[QUOTE="Beemer Nut"]Before you clean up the heads tap the angled passage under the rocker stand on each head at the oil feed to 3/8"-16 thread. Later if needed you can install allen grub screw restictors drilled in different diameters to match your needs. A lot cleaner than installing Holley carb jets. They first must be annealed before drilling but worth the extra effort later.
Thanks
Beemer Nut
Little bits of info like this are very good to know
thanks
Thanks
Beemer Nut
thanks
Your welcome Mike, here to help and by the way nice job cleaning up those heads specially the unshrouding of the exhaust valve that many people forget or not know about. A old dog who learned a few tricks over the years.
Intake, carb, cam, headers and exhaust match the heads?
.....=o&o>.....
.....=o&o>.....
Rogue_Wulff
28
Jul 26, 2011 11:34 AM
overbore66
Jul 5, 2010 10:50 AM
fordaholic-67F100
15
Mar 11, 2005 07:36 PM
