desktop dyno
Old Aug 29, 2006 | 10:35 PM
lilpro's Avatar
lilpro
Originally Posted by fordsrgrt
heck i looked at your location your in WA, you've got possibly the best ford iron head porter in the country in tacoma give scotty a call he'll set you straight on what you need .without porting your heads you wont even be close to 500.here's scotties number 253-988-6648. tell'em richard sent ya
Thanks I gave him a call. Want would you guys say to do, either get my stock heads ported or buy dove heads? IM on a budget of about $2500, so let me know.
Thanks
Michael
Old Aug 30, 2006 | 01:38 AM
monsterbaby's Avatar
monsterbaby
If you buy dove heads about all you have done is spent money on a set of heads that still need ported. The DOVE heads only advantage is they raise the compression, they do NOT flow any better than the D3VE heads, they usually cost more to buy the cores, and they still need just as much work to make power as the later model heads you already have.
Old Aug 31, 2006 | 09:48 AM
lilpro's Avatar
lilpro
im thinking about stroker it out to 514. But i was wondering should i buy a new crank or it possable and cheaper to just get my crank mechained so it would be like the one in the 514 stroker kit?
Thanks
Michael
Old Aug 31, 2006 | 09:04 PM
lilpro's Avatar
lilpro
I found a good deal on a set of dove heads that have been cleanup, would it be worth it? I would still want to port them. Aslo with a higher compression ratio does that effect the higher the octang has to be? If so what is the highes compression ratio i can run while still unsing 92 octang?
Thanks
Michael
Old Aug 31, 2006 | 10:51 PM
airharley's Avatar
airharley
Iron heads I have heard of them living comfortably around 10 to 1 with premium. The higher the octane the more compression you can have. Anything over that and you need to do some serious work to reduce detonation potential. You can pay to have your crank offset ground but in the long run buying a kit would be cheaper IMHO.
bismic
Jul 25, 2022 11:36 PM
bismic
Nov 23, 2016 07:43 AM
f150crewcab
Mar 6, 2015 03:15 PM
Dlasure2
Aug 15, 2013 02:12 PM
robertbourque
Jan 19, 2007 05:35 AM
