Wiper Removal
Old Aug 23, 2006 | 03:34 PM
rmalottwtes30's Avatar
rmalottwtes30
Wiper Removal
I need to know how you can removal the whole windshield wiper assembly cause it is in the way for painting. Thanks
Old Aug 23, 2006 | 05:32 PM
1975Ford's Avatar
1975Ford
There a clip at the base of the wiper arm, lift clip with screw driver and on the other side pry up with flat nose screw driver or small pry bar. Becareful not to chip paint.
Use painter tape on sheet metal where pry bar or screw driver makes contact. Can also use a flat wooden paint mixer for paint to isolate between the sheet metal and pry bar or screw driver.
Use painter tape on the male splines of the wiper prior to painting.
your welcome,
buck
Old Aug 23, 2006 | 05:49 PM
Mil1ion's Avatar
Mil1ion
Are you asking about removing the splined gearing that the wiper mounts to ?
Or
Just the wiper arm ?
If just the wiper arm I like to use a rag wrapped around small piece of wood to pry on... to raise the arm off the splined gear.
Old Aug 24, 2006 | 12:31 PM
rmalottwtes30
Yea I want to remove the whole wiper arm so it isnt in the way when I paint.
Old Aug 24, 2006 | 12:55 PM
Mil1ion's Avatar
Mil1ion
Well then, Uncle Buck answered your question.
They also make and sell a special tool that makes for easier removal if you're un-coordinated
http://www.chain-auto-tools.com/auto...ls/AMM605L.htm
Old Aug 24, 2006 | 02:11 PM
rmalottwtes30
Thanks I got it off with a screwdriver on the clip and pryed it right off. Thanks for the help
Badmrscary
Feb 15, 2011 04:57 PM
marty_1970
Oct 12, 2008 06:35 AM
Maddog521
Escape & Escape Hybrid
Aug 25, 2008 09:23 AM
RabidJade
Paint & Bodywork
Mar 30, 2007 08:59 PM
RA81222
1978 - 1996 Big Bronco
Apr 7, 2006 04:53 PM
