jerking under load!!??
Old Aug 23, 2006 | 02:32 PM
pawnmaster's Avatar
pawnmaster
Cool Jerking under load!!??
I have an '03 6.0 diesel and have been pulling a 31ft 5th wheel about 10,000lbs. When accelerating up slight hill and no down shift the truck sputters and shakes like a backfire jerk and has no power. Ford finds nothing as usual and wants to test drive with load but I wanted some info here first. The noises come from driver side like a blow valve and kinda groins then shutters/jerks repeatedly until I either downshift or level off. I can duplicate this even when on level ground by gently accelerating and not down shifting(torqueshift auto). I have had the reflash done about 4-5 months ago. Also notice black smoke when hard accelerating under load. Truck actually lost speed when climbing very small grade, 1-2% 2 miles long! Any help would be great. Thanks Dan.
Old Aug 24, 2006 | 02:26 AM
Monsta's Avatar
Monsta
Sit. Stay.
Don't know too much about the problem but just wanted to send this to the top of the forum for you.
Welcome to FTE! Hope your service department is able to help you out. You know those 6.0 are kinda known for going through turbos. Maybe that could be the culprit?
Old Aug 24, 2006 | 06:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Moved to 6oh...
Old Aug 24, 2006 | 07:25 AM
vloney's Avatar
vloney
Look at the thread a few down"popping sound". I think you have some stuck turbo vanes.
Old Aug 24, 2006 | 10:48 AM
pawnmaster's Avatar
pawnmaster
Sounds like it might be the turbo as I know there is no wastegate....this turbo was put on about 20k miles ago at bout 40-45k and now I have 65k on the truck..Seems I'm the unlucky one as the trans already fixed at 38k. Any idea if ford replaces with factory turbo's or rebuilt turbos? Have a service appt on friday so I will update.....Thanks. Any other info is appreciated....
Old Aug 24, 2006 | 12:47 PM
vloney's Avatar
vloney
the replacement will be reman probably. There is now a tsb where they clean them first. Dont be shocked, it actually works quite well.
Old Aug 24, 2006 | 03:29 PM
04F250PSD's Avatar
04F250PSD
My truck was doing the samething. I unhooked the EGR and it went away. Might try disconnecting the EGR and see if it goes away.
Old Aug 24, 2006 | 05:03 PM
pawnmaster's Avatar
pawnmaster
thanks 04f250....ill try on my way home......
joshinthe586
2004 - 2008 F150
32
Jul 7, 2018 08:31 PM
noj70
Dec 2, 2017 03:15 PM
Superduty450
2004 - 2008 F150
Jan 27, 2015 11:58 PM
bgnarley
Feb 26, 2004 09:05 PM
