Gas mileage
Old Aug 22, 2006 | 10:06 PM
skrinar70's Avatar
skrinar70
Gas mileage
Just wondering what kind of fuel mileage you guys are getting to see how far off mine is
I have a 96 f150 4x4 302 automatic 3.55s no lift on 32x11.50 15s and get between 9.5 and 11 on the freeway and about 8 in town....
I have put on a K&N and cat back duals which made no difference,
Old Aug 22, 2006 | 10:30 PM
RJPstruck's Avatar
RJPstruck
I get about the same, the last time I checked. 95 f-150 4x4 351
Old Aug 23, 2006 | 06:18 AM
jroehl's Avatar
jroehl
Dang. Did you reprogram your speedo for those tires? My '90 got 14ish in town and up to 17 on the highway, but that was bone stock.
Jason
Old Aug 23, 2006 | 08:04 AM
Conanski's Avatar
Conanski
Wow!! that's bad. I get 12-14 combined and as high as 18-20 strictly highway... cruise locked at 70mph. Frankly I don't know how you could possibly get that bad milage with a 302 unless your foot is burried in the floor mat all the time.
Old Aug 23, 2006 | 08:41 AM
soffiler's Avatar
soffiler
'97 F-250 4x4 351 automatic 4.11 no lift stock tires. 13.5 mpg, summer or winter, loaded or unloaded, combined city and highway (OK that's a bit of an exaggeration... it drops a touch in winter and it drops a touch more with a load). Pure highway might touch 15 mpg.
Your mileage $uck$. Driving habits can make a huge difference. Rolling around those 11.5's isn't helping. 4 wheeling a lot?
Old Aug 23, 2006 | 10:12 AM
skrinar70's Avatar
skrinar70
I drive on the highway with the cruise set at 70-72, I wheel it now and then, and the speedo is dead on according to the radar stands that the cops set up, it has been this way since I got it..... and when I got it it had 30x9.50s on it and the 32x11.50s didnt change it at all, what else can I do to get it a little better??
Old Aug 23, 2006 | 10:28 AM
Conanski's Avatar
Conanski
It's got to be running rich then. Pull the codes.
Old Aug 23, 2006 | 11:55 AM
jroehl's Avatar
jroehl
Again, did you REPROGRAM your speedo? If you didn't, then your speedo and odometer are wrong from the switch in tire sizes. Period. The speedo/odo in your truck runs off the VSS/tone ring in the rear axle/differential, and all it does is count revolutions. The speedo has a correction in it for the overall circumference of the tire then, which has to change if you go to a taller tire.
Jason
Old Aug 23, 2006 | 02:29 PM
ncranchero's Avatar
ncranchero
1995 F150 4x4 S.Cab 5.0L auto 3.31------------11.5 mpg towing 4000-5000 lbs., 12 mpg empty trailer, less than 10 with an egg under my foot watching the vacuum/mileage gauge! By next week the new owner will be enjoying the gas bill! I'm looking for a 97-03 mod motored truck so I can afford to drive again.
I borrowed uncles '03 4x2 reg cab 4.6L and towed the same trailer 100+ miles, empty going and a 1000 lb utility body coming back, and kept my foot in it ... ... plenty of power and over 20 mpg!!
As much as I like my '95 I can't deal with that mileage!
Old Aug 23, 2006 | 05:54 PM
qman's Avatar
qman
When was the last time you replaced the O2 sensor? A bad one will kill your mileage. My 92 4x4 with I6 was getting 10 and then I put in an O2 sensor and then sold it before I could burn up a tank. I also have another identical truck but it's 2wd and it gets 16-17 in town.
Old Aug 23, 2006 | 05:55 PM
redneck4242002's Avatar
redneck4242002
i got a 1994 F150 302 4x2 with 4 inch lift and 32x11.50x15 tires and git 13 and 16 mpg i dont see how u git that bad one of my friends have a 96 f150 that we put a 460 in and 6 inch lift with 33 inch tires and it gits 9 and 10 miles to the gallon
Old Aug 23, 2006 | 06:00 PM
biggreentank's Avatar
biggreentank
What's the most anyone's gotten out of a 351W?
Old Aug 23, 2006 | 08:32 PM
shooter05's Avatar
shooter05
I have a 91 F150 5.0liter 4x4, 32x12.5x15 and get 14 pretty steady. I have my driving split between highway and city.
Old Aug 23, 2006 | 09:05 PM
fordman363's Avatar
fordman363
i get about 10 in my 87 f-150 302. im running headers and flowmaster exhaust. i also put a k&n air filter on it. im runnin 33s stock
Old Aug 24, 2006 | 10:43 PM
cabmustang's Avatar
cabmustang
5th Gear
i thought my mileage was bad. 95 f-250 460 auto with 4.10 LS rear, gets around 11 mpg and i've been able to get 14 mpg mostly highway one time.
