I Have A 99 F-350 Cc, Lb 4x4 7.3 I Have Had Thre New Ford Fuel Pumps Installed In Two Months. Has Any Budy Had This Problem And What Is The Fix. First One Lasted One Month, Second 15 Days, Now On The Third. Line Is Clear Volts Are Right Says Ford. Please Help!!!
Also My Lie -o-meter Stoped Working. I Read Some Where It Is A Easy Fix Can't Find It.
Thank You All,
Do I Have To Drop The Tank To Check This Screen Bloomy63. Its Funny As Soon As Ford Put In The Fuel Pump My Gauge Stoped Working Also. Crash 1040 I'll Check Out That Site. Thanks To You Both!!
Bonanza,
you either have to drop the tank, or remove the bed to access the top of the tank. check out the link below, or if it doesn't work look at the first thread on the list named : FTE guidelines, general information, common mods, etc. under hutch mods the second one gives some good pics of the screen in the mixing valve.
also if your going to all the trouble to drop your tank, you ought to do the harpoon mod, also in the same thread as listed above, this mod will allow you to fill your tank much faster.
Instead of fooling with the mixing valve screens, i got a Prepump and In-Tank Kit from diesel innovations which eliminates the mixing valve and screens completly, so no more having to drop the fuel tank to clean screens, and it also eliminates the fuel quick connects that leak air into the fuel system. air is bad for injectors. eliminating the air will also make your truck run better and get rid of some of the injector knock. if yu decide to go with this, you will need to get a fuel line disconnect tool pretty cheap at the auto parts store
hopefully cleaning, or removing the screens will fix your problem.
what did ford do to ensure that your lines are clear, did they blow out the line back into the tank? which will just blow the crud into the fuel only to clog the screen again, or did they drop the tank to clean the screens out?
Bloomy63, I Don't Know. They Just Said The Line Was Clean And They Ran A Better Ground. I Don't See Any Other Ground Wiring. It Is A Harness That Plugs In Above The Pump. Thanks For The Help, I Mit Have To Drop The Tank If The Sending Unit Is Out For The Gauge. Its Funny Though, It Worked Before They Changed The Pump!
my sending unit ocasionally does not work right and it tells me that i always have a full tank. but next time i fill it up, the guage starts to work, doesn't make any sense, i just live with it, and use my trip so i know when i have to fill up
Dropping the tank is no big deal. The hardest thing is getting the filler and vent hoses off and on. You can drop the tank, do the hutch and harpoon mods listed in the common mods section, and be back in business pretty quickly.
Oh yeah, run the tank pretty close to empty first. A tank full of fuel is not fun to handle. This is one of those mods and fixes that is well worth the time. Good luck!
Thank You Both Pastormiketkd & Bloom63 For Your Replies. I've Been Gone A Couple Days But Your Help Is Appreciated. I Will Do The Harpoon Mod When I Drop My Tank. My Gas Gauge Is One Of Those Things I'd Just Like To Fix. Also I Am Going To Try The Lie-o-meter Fix As Well. You've All Been A Big Help!!
