Sponsored by: Real Truck
window scratches
Old Aug 26, 2006 | 07:03 PM
jonsk's Avatar
jonsk
Well, you can add me to the list. My drivers side window scratched today. Deep enough to catch a fingernail in. Hopefully they will replace the glass also.
Old Aug 30, 2006 | 12:23 PM
rsauve's Avatar
rsauve
The dealer replaced my drivers side window molding this morning. It took about 40 min
and I was on my way. The passenger side looks okay but i will keep a eye on it.
Old Aug 30, 2006 | 01:12 PM
Rabbithunter's Avatar
Rabbithunter
Cool
Took mine in yesterday they said around 4-5 hours to replace glass and moulding. Then I got a call around 4 hours later saying they didn't want to do it. Wouldn't be able to align everything I didn't really understandwhat they were saying. So they were going to have a body shop do it..So now i am stuck driving this pos focus..Everybody seems to stare at me more in the Focus than my f-250. Why is that??
Old Aug 30, 2006 | 03:24 PM
rsauve's Avatar
rsauve
I'm glad i didn't have to have my window replaced, caught the bad molding early
I can maybe understand them not wanting to do the glass but the molding is something
my dealer said was a simply procedure.
Old Aug 30, 2006 | 05:20 PM
Lonewolftx's Avatar
Lonewolftx
Something to keep an eye on . . .
Old Aug 30, 2006 | 05:23 PM
ChaunW's Avatar
ChaunW
So i guess if you have on '04, like myself... then you are out of luck. My Passenger window has the same symptoms.
Old Aug 31, 2006 | 08:57 AM
JRM6868's Avatar
JRM6868
My dealer had a glass company come out to the dealership and install the window.
Old Aug 31, 2006 | 09:13 AM
Matt M, PA's Avatar
Matt M, PA
I regularly wipe the grit off the strips when the windows are down. Takes a second...and avoids the dealership potential to mess something up.
Old Aug 31, 2006 | 09:24 AM
JRM6868's Avatar
JRM6868
Something to seriously consider because my dealer scratched my paint when they installed my replacement moldings. Four trips later after runs in the paint etc. they finally painted the whole door on each side and had to blend the back door and front fenders on each side.
Old Aug 31, 2006 | 02:06 PM
Rabbithunter
Now you guys have me worried.. Suppose to be ready this afternoon. They are retinting the windows when I called.
Old Aug 31, 2006 | 03:39 PM
2005V10F250CC's Avatar
2005V10F250CC
My dealer just called and said the glass is in. I made an appt to get the work done next Wednesday. Hopefully they don't cause me more trouble than I originally had.
Old Sep 7, 2006 | 08:48 PM
2005V10F250CC
Unhappy Dealer still has my truck...
Took the truck in Wednesday. They weren't finished so they kept it another day. I'm driving a dealer supplied Dodge neon. Anyway dealer called today and said there are some issues. They put the new glass in, and when they try to install the rubber as per the TSB, the gap is too small. Ford told them to send it to the body shop to "Adjust" the doors. My service rep went to check it out and says there is no way to "adjust" the gap enough without screwing up the doors. He is keeping the truck another day so he can get on the horn with Ford again. He even mentioned replacing th doors. What a pain in the posterior.
Old Sep 7, 2006 | 09:06 PM
  #28
Matt M, PA's Avatar
Matt M, PA
If I remember correctly, the TSB calls for literally bending the window opening.
If it were me, I would NOT allow them to replace the doors for this. Keep the strips clear of grit, as I wrote above. To replace the doors, they will have to paint almost the entire side of the truck, and who knows how well they will be adjusted, etc.
Old Sep 7, 2006 | 10:45 PM
  #29
Customz's Avatar
Customz
My tint is scratching a tad and I attribute it to the general filthy condition my truck is in 90% of the time. Clean the felt when the windows are down, but I'll take her in at 35k if its bad enouh and they issue a new material or a fix.
Old Sep 7, 2006 | 10:52 PM
  #30
Rabbithunter
Hey guys it only took them four days to fix mine. Then they didn't have the same shop tint the windows that had previously done it, so it didn;t match. Oh yeah and instead of putting limo back on they put like 30 % or something.. Almost forgot the 3 inch long strands of hair between the glass and tint on both windows.. It was purty..So i took it and had to get that fixed $55 outta my pocket.
